Question about HP PhotoSmart C4280 Laser Printer
No software for hp photosmart 7200 series so unable to calibrate new ink catridges need replacement cd to reinstall
    Novelist:
  • 180 Answers
If you need a software for your printer then click on this link below
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&lang=en&dlc=en&product=3204785&
Posted on Aug 25, 2008
I have a HP 6500. I just got all the cartridges refilled. How do i reset them so the printer will recognize them as full?
You can now replace the catridge into position but in most cases the printer driver software can have errors while being in use or is shut down during this maintenance . So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Apr 27, 2011 | HP Officejet 6500 Wireless All-in-One...
Error message Oxc18a0301 on my hp photosmart c6150 printer
The "Oxc18" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
Jul 17, 2010 | HP Photosmart C6100 All-In-One Printer
I have an HP PHOTOSMART C4680!On the screen it apears "Cartrigde problem" and the button is blinking!What can I do to fix the problem?
1.Remove the ink catridge
2.Replace properly
3.try to print
4.if even same problem will be occured then replace with new catridge.
Note: Hp printer come along with a software cd.it has the driver for printer,troubleshooting and maintenence software.in the trouble shooting guide will help to removes and replaces the catridge properly.Also a Quick start guide(A printed sheet) also can help.
5. if Even the problem not solved then unsqurew the printer squrews carefully ,
6.look at the mechanisim if any damaged
7.look any Data cable or Power cable may be damaged (Cables are looking like a white color mica ribbon)
Thank u sir ... All The Best....
Apr 22, 2010 | Office Equipment & Supplies
HP Photosmart C7100 - only 10% of page printer
If your printer does not print the entire page, it is probably because the print head is clogged. Try going to print preferences and locate "maintenance". Find the "clean print head" option and click on it. Follow the instructions. You might have to do it several times, and that will use a lot of your ink, but it might do the trick!
As for the "printer can't get calibrate", that is refers to your print head. That has nothing to do with your cartridges, as they are just tanks with ink in it. Check this link, might help:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1153777&prodTypeId=18972&prodSeriesId=1153777&objectID=c00721373
Mar 08, 2010 | HP Office Equipment & Supplies
I have a 13 month old HP Photosmart C5180 which is now displaying the following error message, "Ink System has failed. Unable to print.." Error: Oxc18a0506. The help message suggests "turn power off then...
your second set of catridges mush help you,, and also,, it seems that your operating system is corrupted,, its better you reinstall the printdrivers first,, if problem persists,, then try reinstall of windows..
Sep 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP 6280 INK SYSTEM FAILURE
Try This :
First check with a new set of orginal HP catridge ; if still it doesn't work then the printer needs to be replaced ; call HP if the printer is in warranty they will do it free of COST ; No. for HP is : 18004746836;
Sep 16, 2009 | HP Photosmart C7280 Printer
Change ink
First confirm the price for the same from local vendor OR HP dealer. Then go to http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&h_lang=en&h_client=s-s-r2515-1&h_cc=sg&h_query=HP+Photosmart+7200+Printer+series and download manual for more details. I would suggest you to please open its cover and remove the cartridge to see its specifications. After buying new ones, put them in printer.
Jun 10, 2009 | HP Photosmart C3180 All-In-One InkJet...
Prints extra blank page for every one page of printed material
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
Aug 01, 2008 | HP Photosmart C7280 Laser Printer
Cannot See Estimated Ink Levels on Printer Toolbox
Unplug the ethernet cable - wait a couple seconds - plug the ethernet cable back in - try again
Mar 18, 2008 | HP Photosmart 3310 Printer
Would not turn off
What printer exactly?? 7200 hp???
Jan 18, 2008 | HP Photosmart D7160 InkJet Printer
HP PhotoSmart C4280 Laser Printer Logo
66 people viewed this question
Ben Johnson
