Question about Coleman 2 Burner Dual Fuel 424-700G Grill
Having a problem with burners not generating .
I changed the generator on my Coleman 413H and thought that would cure the problem as the stove is 20 years old and has worked wonderfully all this time. I then took the burners apart and cleaned the burners and assembled them exactly as I took them apart. My fuel is probably 5 years old.
The burners still do not generate correctly.
So you have a yellow flame, not blue?
my mate had same problem. He now uses unleaded, adding 10 drops Redex to a gallon.
He was also told not to overfill the tank - just 3/4 full.
Works much better but he says not perfect.
Ian
Posted on Aug 28, 2008
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Help
I sometimes have this and I think it is just a bit of fuel left from a tiny leak. If it doesn't go out in a minute or two I pull out the tank and blow out the tip flame. With the valve off there is no more fuel going through.
Mar 26, 2014 | Coleman Vintage 1993 The Powerhouse 413h 2...
413h coleman
Do you mean unleaded? Officially no, unless it's marked "unleaded" or "dual fuel" (in Coleman speak, dual fuel means unleaded gasoline OR white gas) which means all the seals are rated for the additives in road fuel.
Unofficially yes, but gasoline is not a good idea because it tends to clog the generator with soot, it goes stale very quickly and it smells bad.
I would stick to Coleman fuel, Primus Powerfuel or Aspen 4. You probably don't get through so much of the stuff that cost is a big issue.
Aug 03, 2013 | Coleman 2 Burner Dual Fuel 424-700G Grill
I have a coleman 5000w generator. when its running it's rpms are way high and my volt output on the 120 side is 153v how can i slow yhe rpms down is this a carb broblem thanks mark
Hi
Some small generators that do not have a built in AVR are set up to give the nominal voltage at it's nominal loading. this meens if it is unloaded the rpm 's creep up and so does the voltage.
I would suggest running the generator with the load you normally connect to it and ****** the fueling till you get the nominal voltage you require. (record any change you make)
If you are connecting this generator up to a house be very careful not to leave any sensitive equipment connected in the house as the voltage will be jumping eraticaly as it is loaded and unloaded, one item that gets hammered is the electronic contol on boilers/burners.
Regards
Jan 30, 2011 | Coleman Powermate Powermate 5000W...
Generator sizing
Yes, there is. the difference is in the feature that each
have.
Sep 26, 2009 | Coleman Gas Grill Stove
Coleman 425F stove generator
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 14, 2009 | Coleman Gas Grill Stove
No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Dec 18, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Generator 4600 series
Starts Generating 120 volts and whitin 30 seconds is putting out 0 volts, and the generator has high speed
Feb 19, 2008 | RIM BlackBerry Pearl 8100
Coleman 2 Burner Dual Fuel 424-700G Grill Logo
394 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
