Refrigerators Logo
Anonymous Posted on Jul 04, 2011
I have a summit kegerator model sbc 500ss its turns on then shuts off! its clean but just wont stay on! I read something about the start relay to the compressor? what do you think? can you help?
  • Anonymous Jul 06, 2011
    no luck! i replaced the parts but it still does it! they cost 35 bucks. the guy at the appliance place said if it doesnt fix it then the compressor is probly bad! but i'm wondering if the thermometer switch is maybe the prob?
Anonymous
Level 2:
Sergeant:
  • Expert 422 Answers
  • Posted on Jul 04, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
422
Questions
0
Helped
104175
Points
985
I think your right. So check that relay located in the compressor. It has covered so remove the cover and see if the relay has deformity. Also check the overload protection, a similar problem will also cause it- turn on and off it that is near to be defective. You will need a tester for testing that parts.
Nice to help you.
TDD 2 Kegerator clicking and not cooling?
It's extremely rare that the compressor will be any good. Usually replacing the start relay does nothing on these small units. If you know how to use a multi-meter and are any good at wiring the cheapest way to go is to get what is called a 3-in-1 start kit at a HVAC wholesaler. You need to know the model of the compressor and/or the horsepower to get the right one. I would recommend getting a service tech to look it over though. Most likely the compressor is locked up.
I can't get my keg beer under 48 degrees, even at
clean all coils and fins and filter ...don't block exhaust with anything (should be no sugar left to ferment)
1helpful
2answers
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
1helpful
3answers
1992 eagle summit
have u tried starter fluid in the throttle body?you will need to recharge the battery as well
1helpful
3answers
Starts but wont stay running
In reply: if its not the maf there are 2 relays in the relay box i belive its underhood, 1 primes the fuelline to 32psi the second kicks in after it starts, and keeps it running and varies the psi. if the primer relay isnt kicking in then it wont start due to no fuel
THX
Don :)
Does anyone know anything about kegerators?
first send it to me with a full keg so i can check it out what make and model is it and how are you pressuring have you checked the pressure gauge to see what happens when you open the tap
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
