Question about Amana ARDS802 Electric Kitchen Range
Amana range the oven isnt working and the display is showing a "F2" and we just cleaned it today
  • 639 Answers
Hi j grangeruth,
Happy to help you!
If it is 10 years older or more, I would not recommend investing a lot of money into repair!
I think that this problem will be solved only by service!
Try these guys first!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Posted on Aug 25, 2008
Amana Model ARG7102W ERROR F02
Hello, Thank You for using FixYa. I will be helping you today.It means runaway temperature. Test oven sensor for 1100ohms if out by more than ten ohms replace sensor.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kitchen Ranges
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Amana range -the oven does not work, but rest of stove is working.
If the oven isn't working it is either the oven thermostat or the element. If the light and fan comes on to show it's heating but no heat appears, check the fan oven element on the back wall behind the panel. Usually 4 screws.
Dec 11, 2009 | Amana AER5725QA Electric Kitchen Range
After self cleaning today, the oven will not unlock and shows E1 F5 on the display. What do we do to unlock?
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&$^TR
Oct 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F2 on the display!
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor
Apr 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
After a power failure I am getting the code e1 f1 flashing on my display board and it will not go away.
q.gif Why is the display showing E"#"-F"#," for example, E1-F2?
Answer Is "PF" displayed on the control?
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Is the display showing E0-F5?
The Self-Cleaning latch may be interfering with the oven door causing the Self-Cleaning cycle not to work. If the oven door is open and will not lock, press Stop/Clear to clear the display, press and hold the door switch plunger (located in the upper-right corner of the oven front), and the door latch will unlock. If the oven door is closed and locked, press Stop/Clear to clear the display; apply pressure to the upper-right corner of the oven door, and the door will unlock.
Is the display showing E"#"-F"#," for example, E1-F2?
You will need to schedule service.
please do not forget to rate and comment about your experience today. Thank you
Sep 03, 2008 | Whirlpool Kitchen Ranges
Oven wont work everytime we push bake E1 and F1 appear
Aug 24, 2008 | Whirlpool Kitchen Ranges
F2 on Amana ARGS7650SS
well the f2 code on an amana is an over overheat fault code. the best thing to do is replace the oven temperature sensor.
it looks like this
http://www.partselect.com/xq/aspx/Inventory.1508183/qx/PartDetail.htm?SourceCode=5&ModelNum=ARGS7650SS
they cost around 40 dollars but that should eliminate your problem
Jun 20, 2008 | Amana ARGS7650SS Gas Kitchen Range
F2 amana acf4215ac
F-2 is a "oven too hot" fault. says to replace sensor. that wouldnt make the unit heat with out being on though
Mar 14, 2008 | Amana ACF4215 Electric Kitchen Range
Amana ACF4215AC, F2 code
ifyour oven heatsup with oout turning it on, either you have a short in the erc/overlay. Or a wire is shorting againt the metal frame somewhere.
Mar 13, 2008 | Amana ACF4215 Electric Kitchen Range
Amana ARDS802 Electric Kitchen Range Logo
150 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
