This is a forum or social web site
We are at home like you,nothing more
than that,no ties to this site
I would suggest a corroded away fusible link,
is the cause of all your problems
Not the grounds your loosing,the feeds.
Work your way from the battery, till you get to
fusible links,may be in site on inner fender or
hiding in plastic conduit or tape
so just follow the positive connections until i find some corrosion
You are working your way from the battery positive cable to the
starter,then on to fusible links or from the battery along any other
wire leaving it,to fusible links
Your looking for small round fusible links that have basically
corroded wires & leaving you with a car with next to no positive
voltage to half your cars systems
What do you mean by fusible links an I checked the wires from the battery to the starter they are fine
I said starter, then on to fusible links,read what I said
Use the internet to learn what a fusible link is
SOURCE: '96 Delta 88, died when lowering window, one restart, dead now.
All I can suggest is to carefully check out the condition of all +12V power supply leads and ground connections, from the battery to the general power distribution bus at the fusebox.
Pay particular attention to battery terminal posts and any in line maxi power fuses/fusible links and associated connectors, terminals and connections.
Check you havent lost a ground connection between the battery, engine/transmission assy and the general body.
Also worth checking the alternator is working correctly, able to carry the normal running loads reliably. Battery terminal voltage should be approx 14 to 14.5V with engine running when headlights on, A/C blower motor running.
I assume the battery charge condition is ok when these problems occur.
Check electrical and physical condition of the actual Ignition/Accessory switch and associated steering column loom connectors.
Good Luck!
What do you meanby fuseible links and I check the wires to the starter and there fine
