Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
LG dishwasher bottom arm not spinning
Our LG dishwasher is about 3 years old.  Some of the dishes on the bottom rack are not cleaning.  Especially pots or pans.  I have cleaned all the filters and spray arm.  I have just noticed that the bottom spray arm is not spinning. I moved it to a position prior to washing.  Once cycle complete the spray are is in exactly the same position.  Is this able to be repaired and how?
  • 2 more comments
  • Karen Berkey
    Karen Berkey Oct 02, 2008
    I have the same problem. After about 2 years, suddenly the dishes on the bottom rack do not get clean. No parts seem to be clogged. Maybe the arm on mine has stopped spinning as well. Can this be serviced?/
  • theyoungsoz Oct 14, 2008
    Same problem with the arm, is there a fix?
  • Anonymous Jan 05, 2009
    SAME PROBLEM EXCEPT MINE IS THE UPPER ARMS.  NEITHER ONE IS SPINNING AND DISHES ON TOP RACK ARE NEVER CLEAN.
  • Richard drew
    Richard drew Oct 25, 2014
    Hi, I have had similar issues and it has turned out to be the motor that controls the direction the water is to go. Pull off lower spinning arm and all the filters etc from the bottom. you will need a Phillips screwdriver under the whit plastic cover you will see a small semicircular guide, this is supposed to rotate during the cycle to direct the water to either the upper or lower spin arm. There is a small motor and a micro switch underneath the unit ( access is not for the faint hearted as it evolves major disassembly) but the motor is likely to be rusted/jammed. Replacement part is available for around $50
  • 3 Answers
Hi, I have had a similar problem and have found that the motor that controls the flow direction to either the upper or lower arm has seized due to small but prolonged water ingress over many years. Pull off the lower spin arm and run some water through it to prove it is not blocked. Next remove the filter and plate in the base of the dishwasher and remove the four Phillips head screws to move the ducting that feeds the water to the upper spin arm. Now you should be able to see a small semicircular plastic piece that channels the water to either the top or bottom spin arm. Look carefully at the position of the director and decide if it is in the right position to direct water to either of the spin arms, use this knowledge to help you decide if it is working okay. If you can select upper or lower cycles try them and check if the director moves to the right place.This is a good time to check the pump pressure. Run the machine, without rebuilding the insides, open the door during the cycle and you should find plenty of water splashing around and you can also check the director position.
Okay, assuming that the director is not moving it is likely that the little drive motor has had it. There is also a little micro switch beside the motor which may have failed but I believe that a siezed motor is most likely. Replacement motors are available for about $50.
Access to the motor is not for the faint hearted, it requires substantial disassembly but only a phillips head screwdriver is required to get it done. You will just have to follow your nose to pull it apart as it is a little too involved to describe what to do.
Posted on Oct 25, 2014
  • LG Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
syte
Posted on Sep 29, 2010
Bottom water sprayer not spining
If the dishwasher won't clean dishes, check the lower wash arm assembly. If the lower wash arm isn't getting water, all of the dishes in the lower rack will come out dirty. Check to be sure the lower wash arm assembly spins freely. Also check to be sure the little holes in the lower wash arm aren't clogged or blocked.
Aug 28, 2014 | LG LDF6810ST Stainless Steel Built-in...
Sears dishwasher not cleaning
You may have a bad pump, or the pump intake (inside the bottom tray, under the dish racks) may be clogged with crud from years of dirty dishes.
Jul 31, 2014 | Kenmore km 665.15765692 3376066 Det Latch,...
My dishwasher isn't washing the dishes on the bottom rack? The silverware is clean and the top rack ins clean..
make sure the lower spray arm is free from objects in the ports and spins freely. If you still have a problem LG is offering some customers an pump upgrade free of charge depending on the age of you dishwasher
Sep 01, 2011 | LG LDF6920ST Stainless Steel 24 in....
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
LG LDS5811 top rack not cleaning
I Have the same issue, it sounds like the arms try and start up 4 times then each time power back down, the top arm is not spinning at all. On the fifth time a I hear grinding and then the mid and lower arms spin, soap streaks down the door, nothing stuck in any of the arms, 16 months old, 750.00 out of pocket for junk!
Oct 08, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Washer arm not working
If your dishes are getting clean, then your problem is a "feture" not a failure. The LG LDS5811 has a Verio motor/check valve that switches between cleaning the upper dishes and then the lower. Depending on when you open the door, one arm will not be spinning.
All the presure is routed either to the lower or upper arm, so it really does help - especially with a water conserving model like the 5811.
Good Luck!
Mar 06, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
1,814 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
