Question about AEG B2100-4 Electric Single Oven
AEG double oven- fan assisted not heating up
Hi - my fan assisted AEG oven stopped heating and tripped the fuse switch. The fan still spinning but no heat. Any ideas?
  • 2 more comments
  • deb5050 Aug 25, 2008
    thanks so much, element not visible so guessing its behind the panel at the top - wish me luck!
  • Anonymous Mar 17, 2014
    fan and grill will not heat on aeg
    fan and grill will not heat on aeg but electric ok
  • Anonymous Mar 23, 2014
    has just suddenly stopped and have switched off and on again but still not working
  • 139 Answers
You oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Posted on Aug 24, 2008
AEG double oven/grill stopped working
It appears the oven has shorted out. Try checking the breaker box and see if any switches have been flipped. If this is not the case a new oven is in order.
Jan 24, 2014 | Ovens
I have an AEG Competence Single oven model B2100-1-w The oven is not reaching or holding temperature I have noticed the fan is not spinning
Hi steve sounds like your fan motor is faulty they are not very powerful any resistance in the bearings can stop it starting. oiling the bearings wont help you need to replace the motor also it will have damaged the element no air circulating it will of overheated. an overheated element usually lasts till xmas morning.
Nov 09, 2010 | AEG U3100-4 Electric Double Oven
AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Feb 05, 2010 | AEG Ovens
My AEG Electrolux fan assisted oven does not heat up. The lights and everything works just no heat.
If the fan and light work o/k, then you need to replace the oven element.
Please rate my solution.
Nov 02, 2009 | AEG U3100-4 Electric Double Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
AEG Competence Double Fan Oven Fault
Sounds like oven element is faulty, disconnect it and try again, if it does not trip, then it is definately the element..
It is easy to replace.
Plz leave feedback.
Sep 22, 2008 | AEG B2100-4 Electric Single Oven
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
AEG B2100-4 Electric Single Oven Logo
535 people viewed this question
Top AEG Ovens Experts
Sal De
Are you an AEG Oven Expert? Answer questions, earn points and help others
