Posted on Jul 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can Minolta Copier EP 1030 can scan legal size documents
Adorjani Laszlo
Level 3:
  • Minolta Master 1,316 Answers
  • Posted on Jan 04, 2012
Adorjani Laszlo
Minolta Master
Level 3:
Answers
1316
Questions
Helped
457297
Points
2563
EP series is analogic copiers,no print ,no scan.
2 Related Answers
Anonymous
  • 17 Answers
  • Posted on Jul 23, 2008
SOURCE: minolta ep 1030
It is not actually a paper jam - when the copier detects a malfunction, it simply stops everything. Paper jams all have "J" codes (J1, J3, etc.).
A CF3 indicates a problem with the ATDC system (Automatic Toner Density Control). The output from the ATDC sensor is outside normal specs.
Possible causes would include the copier being run (and reset repeatedly) without toner, the imaging unit not being properly installed (or not present at all), use of toner not compatible with the unit, a defective ATDC sensor or (least likely) PWB-A.
Anonymous
  • Posted on Nov 27, 2009
SOURCE: Minolta 1030
ecrie probleme j3
Ep 1030/1031F gets black strip down side of paper about an inch wide
Odds are you need a new drum cleaning blade. The only problem is trying to find parts for the copier. Good Luck
MINOLTA EP 1030 CF3
Have the image unit replaced or have tech come out and have the developer replaced the counter cleared and run F8 run, after the developer is installed. Also replace the fuse on the image unit so the copier thinks its getting a new image unit when only its getting a developer changed. Try finding a image unit first. try below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
My photo copier keeps saying pc ?
I worked on a EP 1030 copier and the error PC is when the machine doesn`t pickup paper. Make sure pickup roller is clean and there is paper in paper tray.
1helpful
My minolta ep 1030 is printing copies with a line down the page
Check the hot roller for a scratched surface. Otherwise you may have a bad photoconductor.
Error code j3 for ep 1030
j3 - exit jam
search for a lever at the exit point of the copier, you sould be able to see the sensor at the lower part of the fuser. I may bejamed or the flag broken.
1helpful
My Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
Scanned legal doc to email comes out landscape and prints on lett
select scan mode, then select legal on paper select. If you select paper before loading document into the ADF it should go with the size you enter.
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
4helpful
Minolta ep 1030
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
