Question about Panasonic DP190 All-In-One Laser Printer
DP-190 Blank Copies
I had to replace the write unit in a panasonic DP-190 and now the copies come out blank. I've taken the machine apart 3 times and even tried to put the old write unit back in with no luck. I've checked and reseated connections and also changed drum and developer and the trasfer roller seems to be ok. Any ideas?
  • Paul Homuth
    Paul Homuth May 11, 2010
    first do a internal print out.
    fax button-function-6-4-start
    something will print out let me know if that is blrank
  • 300 Answers
By the write unit i guess you mean the LSU. If you've already ruled out the the image drum and transfer roller you're only left with a few possibilities. I'm also guessing this fault only happened after you replaced the LSU??
1 is there something obstructing the beam from the scanner to the image drum.
2 have you damaged one of the 2 harnesses going into the LSU (check the contiuity) also check the connections on the system board.
3 The high voltage power supply may be faulty.
4 The system board may be faulty.
I repair lots of the DP180's the european version
Posted on Aug 25, 2008
Replace toner and drum and when i make copies they come out blank
This comes from the manual for your device:
A blank sheet is ejected.
You placed the document facing the wrong way when using the copier.
The other party placed the document in their fax machine the wrong way. Check with the other party (KX-MB781 only).
Try putting a page in and seeing if it copies blank and then putting it in the other direction. Have you had the same issue with printing?
If everything comes out blank it is the fuser or heating element.
Oct 25, 2012 | Panasonic KX-MB781 Laser Fax, Copier,...
Blank Copies
Check the drum unit,DP, connection upper karuna, lower karuna, is karuna sparking?
Sep 09, 2012 | Office Equipment & Supplies
BLANK COPIES FROM KM 2550
first chek dev unit toner? pls insert toner 1087+ 1087+ 130 set dev enter ok then 10 mnt wait and check drum and dp closing time corect sitting or chage edge of dp unit you cleang time smothing wrong?? comng blnk copy
Aug 03, 2012 | Kyocera Mita KM-2550 All-In-One Laser...
Panasonic DP-190 copier problem
The printer is obviously good but the scanning software used for making copies must have an issue. Did you check the scanning bulb for proper operation? If bulb is good then the issue lies with the scanning section of the machine,.
Aug 30, 2017 | Panasonic Workio DP-190 Multifunction...
I have Panasonic Workio DP-2310 copier and there were multiple lines the length of the copy .I cleaned entire copy and drum area and installed new toner cartridge now the copies are coming out blank , no...
check you drum charge connection between drum unit and developer unit, two metal strips at back that contact when the two unit are closed. none or bad connection means no charge and then blank copies
Feb 01, 2010 | Panasonic Workio DP-2310 All-In-One Laser...
Copies are blank
This is most probably a problem with the laser unit on the printer. Try cleaning/replacing it. You will need to take it to a reair agent.
May 19, 2009 | Panasonic DP-150FX Laser Printer
KONICA 7020 - Blank copy
I have never heard of a developer moving backwards!!!!!!!!!!!!!!!!???
the motor that runs it, the .... there is too much involved to mention. A developper moving backwards will spill so much toner in the machine anyway.
If you get a copy and then it goes blank, that tells me you have a problem with the SEPERATION UNIT, it may be shorting out causing the paper to rise against the drum giving you blank copies.
A blurr copy tells me there is a problem with the Scanner/Optics area. maybe the rails that the scanner run on are too dry or has a problem, the optics(mirrors) may be misaligned.
Not sure what you mean by (hanging) ??
Jul 31, 2008 | Office Equipment & Supplies
Fuser belt unit dp-c262
When making copies, there is line on the copies. How do I resolve this issue?
Katie
Apr 09, 2008 | Panasonic WORKiO DP-C262 Printer
Ricoh 6513-Blank copies
hi im jules_09,check the transfer unit then the drum charge unit blank copies indicate that there is no high voltage that attach the toner to the drum.
Nov 15, 2007 | Ricoh 6513 Copier
Panasonic DP190 All-In-One Laser Printer Logo
83 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
