Question about 2wire 2700HG-B Router (2700HGB)
2wire 2700hg-b wired router wont allow setup of Linksys WAP54G access point
When in the setup of the WAP54G Linksys Wireless Access Point, the setup software is not able to detect the WAP on the network to setup. Is the router not compatable with Access Points, or is there a setting that must be changed in the router??
Thanks
    Novelist:
  • 143 Answers
The ip address of the 2wire router might be different from the ip address being used by the wap54g (ip address is 192.168.1.245 by default) that's why it's not being detected.
you need to directly connect the wap54g to a computer and set the computer to use a static ip address (ex. 192.168.1.240) and run the cd that came with the wap54g. you need to set the ip address of the wap54g to the same segment being used by your router to make them see each other
hope this'll help you and just ask me if you have other concern
ciao!
Posted on Aug 26, 2008
My access point works fine for about an hour then the act indicator goes off and it becomes undiscoverable for my laptop. what is the solution?
Ensure that your laptop WIFI is correctly setup and specifically turn on the option:
'connect even if the network is not broadcasting its name SSID'.
If it does not help, try the followings in order:
  • Reset the router (make sure that you backup your current router setup or know how to reload i / reconfigure).
  • Change Wifi Channel on your router as the current channel frequency might be clashing with other wireless devices (handsfree?).
May 02, 2011 | Linksys WAP54G (WAP54G-UK) 802.11b/g...
Internet connection is fine when my PC's connected directly to the modem. The router connects fine. But won't let the wired PC online. Under the "status" bar the "router" tab won't show the correct...
here are times when there is a need to connect a wired computer to an access point in order to set it up. To connect a wired PC to a Linksys access point, follow the steps below. Step 1:
Connect the PC to the Ethernet port located at the back of the access point.
Step 2:
Assign a static IP address on the computer. For instructions, click here.
NOTE: To assign a static IP address using Mac, click here.
The Access Point can be configured in four different modes:
  • Access Point
  • Access Point Client
  • Wireless Repeater
  • Wireless Bridge
The Access Point mode allows wireless clients to connect to the access point and routes traffic between the wireless and wired interface. Use this mode to create a standard wireless Infrastructure network. For instructions, click here.
The Access Point Client mode allows this device to act as a wireless client. You can connect a wired PC to the access point to connect to a wireless router or another access point wirelessly. You can enter the MAC address of the Access Point or use the Site Survey button to select the Access Point you want to connect.
NOTE: The WAP54G will only communicate with another WAP54G when set to the Access Point Client. For instructions, click here.
Sep 05, 2010 | Linksys Wireless-G WRT54G Router
I want to instal my wap54g wireless access point. i lost the cd that came with it
Go to this web site and download your setup.
http://www.linksysbycisco.com/US/en/support/WAP54G/download
Jan 09, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
My laptop says connected to Linsys router but no internet connection, yet the desktop is connecting to internet
saya ada dua access point, yang digedung A saya memakai access point linksys WAP4400N dan di gedung B saya memakai access point linksys WAP54G. sekarang sudah tehubung masing2 access point, permasalahannya sekarang adalah kalau memakai laptop tidak bisa connect secara automatis, tp kalau secara manual atau memakai IP Address baru bisa connect, tolong gimana solusinya....
Nov 02, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
I trying to fix a small office network and need some help. I have a netgear ds116 hub that currently has a linksys WAP54G access point connected to it for wireless access. The access point is not encypted...
So have a hub and a wireless access point at office.
Do u have a router in the network at office ?
The default IP address of the WAP54G will be 192.168.1.245.
The Sonic firewall is a different thing.
I think you are accessing the set up interface of the sonic wall with the IP address 192.168.1.1.
Where is the access point connected ?
Is it connected to the sonic firewall ?
The access point does not have the DHCP server.
Click Here for more info about Access point
Oct 07, 2009 | Linksys Wireless-G WRT54GS Router...
Can i use my 2700gh-b dsl 2wire wireless modem as wireless router to time warner cable? If so, how? I'm a newbee. Please help! Thanks in advance.
This Router designed for DSL internet. It wont work for cable internet. Best thing is to trade in with a normal access point or wireless network router. Like Linksys, Belkin, Netgear etc
Jun 26, 2009 | 2wire 2700HG-B Router (2700HGB)
I am trying to hook up a omni antenna to a wrt54g is it possible in a motel setting
Hi there If u have a linksys wrt54g router. the omni antena will not give u the maximum wireless signal if u are going to set it on a motel, u need to setup a wireless access point in order to broadcast the signal or to repeat the signal u need a wireless access point and the model # is WAP54G..
here is the link just incase u want to know more about on how to set up a wireless access point
1. How do I configure an access point as a wireless bridge?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4194
2. How do I configure an access point as a wireless repeater?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4200
3. How do I configure an access point as an access point client?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4202
4. How will I know if an Access Point is configured as an Access Point?
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4165..
check this out and i hope this will solve ur concern..
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Need Setup CD for WAP54Gv.2 wireless router
perhaps this can help you
http://www.shooter.co.nz/Linksys_WAP54G_setup_procedures.pdf
Jul 14, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Installing a Linksys Access Point to a Verizon Actiontek wireless router.
The IP Address of WAP54G is 192.168.1.245
Connect a computer to the Access point.
Assign a static IP Address to the computer, like : 192.168.1.10 , the subnet mask should be 255.255.255.0
Open the setup page of the Access point, by typing 192.168.1.245 in Internet Explorer / Firefox. Configure the wireless settings, Change the IP Address to the range that of the Actiontek router.
Save settings. To know about wireless security, click here.
To check the latest update on Linksys products, click here.
Hope that helps :)
Mar 28, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
Sep 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
2wire 2700HG-B Router (2700HGB) Logo
539 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
