Question about Maytag Dryers
Maytag dryer model #mdg600bww the dryer starts, but about 15 seconds the flame stops, the dryer continues to run with no heat.
Amigaman
  • 248 Answers
SOURCE: Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Posted on Nov 11, 2007
aborcass
  • 2651 Answers
SOURCE: Maytag gas dryer model # SDG305DAWW
replace the coils atop the burner assy itself, part number 279834..
Posted on Dec 21, 2008
  • 50 Answers
SOURCE: Dryer flame shuts off after about 30 seconds
this sounds like a clogged vent more than a thermostat. go outside with the dryer running and see if hot air is blowing out the vent. if not check outside vent for birds nest etc, inside make sure the vent is straight any dips in vent could cause water to build up clogging the vent. try this first if it doesn't work write back
Posted on Jan 23, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Maytag LDG5914AAE Gas Dryer gas shuts off after 15 seconds or so
The coils can be replaced, also I would check your dryer vent and make sure that the vent is clear and ffree from any blockage
Posted on Apr 13, 2009
Greg20
  • 149 Answers
SOURCE: Maytag Gas Dryer - Flame trips high limit Tstat
firstly..is venting blocked? disconnect venting and try it. if problem persists then replace hi limit. assuming what you just told me was correct.
Posted on Jun 11, 2009
I would like to find out if my Maytag Neptune dryer has heat coils or just a Flame sensor
Go to YouTube and type in - Maytag Dryer heat coils and see if it comes up. Also type in Maytag Neptune Flame sensor on the next search.
Oct 05, 2015 | Maytag Dryers
Maytag gas dryer LDG7500AAL flame won't stay on longer than about 5 seconds.
The resistance is too weak in the hot surface ignitor to keep the gas valve open and requires replacement.
Dec 22, 2013 | Dryers
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a gas dryer not heating properly. it heats up for about 15 seconds then stops heating for about 15 seconds and continues doing the same. i ohmed out my cutoffs and stats and fuse. all good. im...
Does the actual flame come on or just the igniter? if flame comes on I would start be disconnecting the vent from the dryer and then running dryer. If still the same problem you can rule out a vent restrictiion problem. If its just the igniter coming on with no flame then check your burner coils on the gas valve. They should check less than a couple K ohms. A bad coil will read infinite ohms.
Sep 22, 2011 | KitchenAid Dryers
Model SDG305DAWW, gas unit...begins to dry and then stops...timer stops and unit continues to tumble but no heat...turn unit off and wait for about 2 hours then can dry again....replaced cycle timer,...
Sounds like you have the same problem I did. You need to replace the flame sensor. Takes about 15 - 30 minutes. You can order the part online here
Feb 06, 2010 | Maytag Dryers
My dryer ignites and after a few seconds the flame goes out
hold and assist coils
with model number i could get you the part numbers
Sep 29, 2009 | Maytag Dryers
Whirlpool model GGQ8858EQ1 gas dryer starts, gets flame and begins heating. then after a short while flame shuts off and i hear a chattering noise somewhere near the bottom of dryer. It lasts for about...
The problem is your gas valve solenoids (coils). There are usually two of them mounted on the burner assembly. One is the MAIN coil, the other is the SECONDARY coil. It is recommended that you replace BOTH of them at the same time. Replacements can be purchased on line at appliancepartspros.com. Just type in the model number you provided and look under the "Burner Assembly" section for items 13 and 14. I hope this helps you.
May 05, 2009 | Whirlpool Dryers
Apr 13, 2009 | Dryers
I have a gas Gas dryer with low heat. The igniter is good, the gas valve opens and I get a flame, but it never heats up past 89 degrees. I'm guessing there is a secondary gas valve or something that kicks...
if the vent line is blocked or lint is built up in the duct where the lint filter slides into the flame will only stay on for like 5 to 10 seconds or the gas coils are bad,when the coils are starting to fail you'll have heat for the first 10 to 15 minutes and then no heat,when the coils cool down they will work again,these are the two most common problems with a gas dryer,try removing the vent line from the back of dryer and run it to see if it heats any better if so you have a block in the vent line.or run the dryer for 15 minutes and look at the flame and see if it still ignites,if not the coils are bad.next time send the brand name and model number off of the dryer,open the door look around the opening where you put the clothes in and you'll see the model number good luck.if those two things check good you could have a bad cycling thermostat located on the blower wheel housing but i would check for a block in the pipe or lint filter duct.
Nov 29, 2017 | Maytag Neptune MDG5500AW Gas Dryer
Dec 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
292 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
