Question about Philips GoGear HDD6330 MP3 Player
Gogear 6330/17 - Creating/Adding Playlist
Ok whenever I try to make a playlist in windows media player, it doesn't add it to the player. Does anyone know how or have a link to show me how I would do this whole playlist thing? It's really annoying having only one playlist (All tracks etc..)
  • akyraone Sep 10, 2008
    I have create playlist in windows media player and i take this in my go gear but when i play on in this there isn't the playlist that i had created but the song are save in all songs
    excuse me for my english
  • 8,596 Answers
You MUST use Windows Media Player 10 - Windows Media Player 9 or 11 will not transfer the playlist correctly.  Once you have version 10 installed, then the instructions in the HDD6330 user manual will be accurate.
Posted on Sep 14, 2008
How to add a playlist??
There are two ways in which you can add a playlist....
1......by using your playlist via the player...
2......or by creating one using the computer....
First lets see the one using the player...all you have to do is go to the song navigate option...highligh the song that you wan to add to your playlist and then click the record button.you will be given two choices..one add to my playlist and two erase.....click the add to my playlist option and you will have the song added to you r playlist.....
second method is create a normal playlist using windows media player with the correct directories in the player and then copy the file to the player...
now when you press the menu button for a second or two in the songs menu...you will be displayed two choices....one file navigator and the other is playlists....
click the playlists option to access the playlists....
Dec 23, 2010 | Transcend T-Sonic 850 Digital Media...
Lookins for software
HDD14xx GoGear:
manual
software and drivers
The manual shows how to make lists and transfers with your player.
A short guide on how to use Windows Media Player 11:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your music maps and ad songs by drag and drop method
onto the right saying "Drag items here"
4. when ready adding songs in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Sep 11, 2009 | Philips GOGEAR SA6045 MP3 Player
Creating Playlists for GoGear Aria 8gb player
If you want to make a new playlist for your 8 gig GoGear Aria, all you have to do is highlight the songs you want to add, then right click the mouse and choose create playlist. Name the new playlist then cut and paste it into "Playlist" in the music choices and there you go. No WMP needed.
Aug 18, 2009 | Philips GOGEAR SA6045 MP3 Player
Sa3020 PHILIPS MP3
That particular model is not capable of recognize playlists. The playlist option is only for creating a "Playlist on the Go" from within the player itself.
Jan 06, 2009 | Philips GOGEAR SA6045 MP3 Player
Playlist dont Show
That player is set up for playlist transfer through Windows Media Player 10 only - you can either: 1) rollback your Windows Media Player to ver. 10; 2) attempt the firmware upgrade by running the Update tab in Philips Device Manager (may not work); 3) reinstall the installation CD - select Repair as your choice - it will add a plug-in that it may have skipped during initial installation. Good luck!
-Tha Mp3 Doctor
Dec 29, 2008 | Philips GOGEAR SA6045 MP3 Player
Phillips 4gb Go gear playlists
ok heres what ya do.
connect to laptop/computer.
go to "computer"
find the player -- open it
internal storage -- open it
playlists -- open it
right click any of the playlists and click properties.
click the references tab.
go back to the folder called music in the device.
click and drag the songs into the window called references.
when finished click ok.
should work!
Nov 30, 2008 | Philips GOGEAR SA6045 MP3 Player
Playlists
The SA33xx series does not support playlist transfer. You can create a Playlist on the Go as the manual suggests, but it will not allow you to transfer your own playlists.
Oct 05, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
·         Open up Windows Media Player(WMP) on your computer. To add a track to a playlist on your computer using WMP, click to highlight an item.
·         Right-click on the item that you want to add, then select Add to Playlist. A pop-up window will appear. Select an existing playlist or add a new one. Your selection is now added to your playlist.
·         Delete a track. When you do not want a track on your playlists anymore, you are able to delete it. To delete tracks and playlists, click to highlight an item. Right-click the item and select Delete from Library to delete it.
·         To Edit track information, click on a track. Right-click and select Edit. Click on the text boxes to edit relevant information.
·         Once all changes have been made, connect your GoGear to your computer with your USB cable and download the new playlists.
Sep 24, 2008 | Philips Audio Players & Recorders
Playlist
Not possible on this model - you only have the Playlist On the Go option
Jul 23, 2008 | Philips GoGear Flash MP3 Player
Big problem with play lists
According to the manual for most GoGear's, you have to have automatic synchronization enabled in Windows Media Player for the playlists to transfer correctly.I still have not been able to verify if this is true, since I have been able to transfer playlists fine with and without auto-sync engaged.
I haven't tried a 3115 specifically, but with an SA4111 and an SA5125, I just created the playlist in Windows Media Player 11, right clicked on the playlist name after it was created, selected "Add to Sync List," and then "Start Sync" with GoGear connected. I used this method, because it seemed more likely to add the songs AS A PLAYLIST rather than just dragging and dropping the tracks WITHIN the playlist.
As I look more closely at the documentation for the SA3115, however, it does not have the same playlists options as other GoGear's - it seems to limit you to Playlist-on-the-Go. I know that the GoGear will not recognize folders that you create in Windows Explorer, so that option is out. You can connect the GoGear, and see if a Playlists folder appears in the left-hand pane underneath the icon of the GoGear in the Sync tab. My gut feeling, however, is that this player is just not as equipped as other GoGear models for playlist transfer. I'll go back to the lab on tuesday and see if I can find anything new.
-Tha Mp3 Doctor
May 25, 2008 | Philips GoGear SA178 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
132 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
