Question about Motorola For MT1000 MTX800 MTX90010v 1200mAh NiCd Battery 2-Way Radio
After reading programming Radio Died
I just got back into a VFD and have had the mt1000 since 1990 with no problems with it. I reprogrammed the new radio freqs into radio about 2 weeks ago and had some trouble getting all the way to 100% on the upload side, after about 2-3 tries got the program in. The radio worked fine but didn't get the power up tone but everything else seemed fine. Friday I got the tone out codes for the new FD and was tring to program them into radio, when I noticed the back of the radio was really hot (one of the screws that holds the belt clip on). I disconnected the programming cable and RIB, now the radio is completely dead, will not do anything. Check the Battery voltage and everything else physical - but nothing. Now everytime I connect and try to read or program radio I get a serial bus acess error 003. Can anyone give me some ideas as to how to get working again.
  • Motorola Master
  • 1,654 Answers
Unfortunately you have a corrupted code plug. The radio will need to be serviced to clear the corruption. Or if you have a clean copy of the original programming, you can try reprogramming it. (Note: Do not use the version you had saved which led to the corruption.)
Posted on Aug 25, 2008
How do i change the display light on my radio
if the dial light power wire is hot, parking lamps on and dimmer to max
that be a bad radio.!
and like all radios ever made, it needs to be bench repaired.
how , is like them all
lid off
lamp out. replace it.
or if VFD , new VFD . or LCD back lamp or what ever is there..........
most cars this old have a newer radio. not stock
and each car is sold with 3 or more audio options, new.
i cant predict what car came with or what's there now.
Oct 09, 2014 | 2004 Jeep Grand Cherokee
The lighted display has started to darken - cannot read frequency display, etc. Is there a way I can fix it by changing a bulb or an LED?
This problem is not depending on a kind of LED or bulb. The reason is that the display is a VFD (Vacuum Fluorescent Display) with no additional illumination.
The most common problem with VFD is, that the heater of the VFD is going bad. You can't change it because it is built-in. For experienced repairman it is possible to higher the heater voltage or the anode supply to gain the brightness a bit. But thats a tricky thing.
Sometimes it may help to clean the display cover from inside. This is what you can do first. The reason for getting dark by dust inside the cover is that the VFD is working with a anode voltage wich is a bit higher (about 30V - 50V). This sucks the very fine dust electrostatically into the casing.
To clean up the protective display cover from inside, remove the casing and also the cover in front of the VFD and clean the dsplay protection cover (the VFD istself is usually clean). Maybe that's it - but maybe not (that means the VFD is going bad).
Hope it helps.
Oct 14, 2013 | Aiwa AV-X120
I have a 1999 beetle. My wife was driving it and the radio shut off. she says it was acting like the battery died. But it all came back on without her restarting the car but the mileage counter had...
I suspect that you have a theft deterrant radio in the bug. Ialso suspect that the battery got disconnected somhow, probably a loose post connection, in which there was no electric power to the system for some time. A theft deterrant radio has a chip in it that is programmed to operate the radio. when power is lost to this chip for 30 minutes or more, that chip forgets its programming, thus anyone that steals the radio could not use it. The first thing you want to do is track down the gremlin that caused the power failure in the first place. That would be cleaning the insides of the cabel clamps with emery paper and clamp them tightly. The radio will have to be reprogrammed by a dealer as they are the only ones that have the programming equipment to do this.
Feb 09, 2011 | 1999 Volkswagen Beetle
Thermal overload occurs
I too am experiencing an "oc2" on my gvx1000-1.5-t unit after replacing original motor with near identical, however, relacement motor is rated for 60hz and the vfd is programmed for 50hz. but I don't have a manual nor does my machine manufacturer, so I'm trying to source a manual to alter the vfd parameters for the new motor. My original problem was a locked shaft on the original motor and caused the oc2 fault, but I bent the shaft trying to break the motor flange free and now my spare won't work either :-(. Try removing the load from your unit and see if you still get a fault, if so, you probabley have an enternal problem with the vfd. if by removing the load you don't get a fault, check for anything seized in the drive components, including the motor shaft itself(bad bearings will do it!). An amp test of your load, if it runs long enough to test, will tell you if you're exeeding the vfd's programmed full/max amp set point. Adjust the set point or remove the cause of the excessive amp pull. Good luck. Wouldn't happen to have a manual on the unit I'm looking for, would you?
Jan 23, 2011 | Inverter Bonfiglioli Gvx1000
How to reprogram two way radio, its a motorola gp 339 and its set to 5 channels from when i brought it, can i reset it or reprogram it to normal uhf channels?
In order to reprogram this Motorola GP339 you need to have a programming software, radio interface box and programming cable for this radio then you can read and change frequency in it. To reprogram to UHF channels this radio must be in UHF band. Good luck!
radcom907
May 14, 2010 | Motorola GP300 Compatible 2 Way Radio...
Electrical problems with my 96 honda accord
This happens because the removal of the current to the computer or CPU gets de-programed. You may be able to solve the problem (if it comes up gain ) by disconnecting the negative cable with the engine off. Then renstalling it back after a minute.This will reprogram the computer.
Apr 05, 2009 | 1996 Honda Accord
Radio doesn't work after battery died, recharged and later
hi.
find your radio here...http://www.ibiblio.org/tkan/audi/radios/radios.html
then follow link for program instructions
good luck
Mar 27, 2009 | 2002 Audi TT
Radio Communications Logo
149 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
