Sound how do i get tv sound through cinema system. tv connected to surround with £80 hdmi lead and also red n white audio lead £40
  • 10,594 Answers
?? what??
Posted on Aug 24, 2008
Connect tv to surround sound system
Connect a RCA cable from the TV Audio output (red/white)
to the surround sound Audio Input (red White)
If your TV has a "HDMI OUT" and your Surround System has a
"HDMI Input" Then use a HDMI cable instead.
You will need to set the source on your Surround System to
the audio source you use on the surround system(input)
On most it will be TV or Auxiliary.
Sep 30, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
No sound from TV when connecting Philips HTS3530 Home Cinema to Sony 32CX520 TV, but there is sound from radio and satellite box. Connection through scart or/and red, white and yellow plugs. There is no...
I am buying Philips HTS3530 home cinema, and I saw that there is some difficulties connecting it to Tv (40' Samsung smart Tv) Is there any cable which u need buy (i have HDMI).
Thank you
Sep 14, 2011 | Televison & Video
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
Aug 26, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
How do i connect to sky hd and sony kdl 40w 4710 and dav-is10 i have hdmi from skyhd to tv and hdmi from home cinema to tv what else is required as i cant get surround sound from tv
you need a Optical audio cable, run this from the back of your Sky HD box to the Surround sound. Not all Broadcast are transmitted in DD so press your i button on the sky remote and you will see this on the yellow bar above the program information if it is..
Might be worth running a set of White and Red audio cable from the HD box to the Surround sound as well that way you can just mute your telly and have the lot coming through the surround sound system.
Hope this clears things up for you
Little Dish Fitter
Jun 05, 2009 | Sony DAV-IS10 System
Surround sound for ps3 with a hdmi cable..
you need a HDMI connection for your stereo. HDMI is an all in one cable so if you don't get your sound in/out you need to hook up to just the RCA's, if you get a reciver that has an HDMI input you will solve this. then you go HDMI to Reciver then HDMI to TV
Mar 12, 2009 | Sony PlayStation® 3 (60 GB) Console
I have a samsung cinema system rts he10t and a samsung lcd tv le32a556 and i am trying to get the sound from the tv to the cinema system i have a hdmi cable and the red and white phono cable connected but...
make sure you have the audio cables connected to the OUTPUT on the tv & the INPUT on the surround sound(from your desciption sounds like you have them reversed)hope this helps,thanx for using fix-ya,please rate all replys
Nov 17, 2008 | Audio Players & Recorders
Sharp television and panasonic cinema system with hdmi connection
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Nov 17, 2008 | Sharp Aquos LC-32D40U Television
Panasonic HDMI surround system problem
The HDMI cable connection on your system is a video out to your TV.
To get audio from the TV so you can hear it through the system, you need to add a cable from the audio out of your TV to the "aux" input on the panasonic system.
This is most likely a red and white connection which will give you stereo, or pro-logic surround from the home theater system.
Dec 23, 2007 | Audio Players & Recorders
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
