Question about Brother HL-2170W Laser Printer
It's printing garbage
Background: Macintosh iMac 5.1, running OSX Leopard (10.5.4). Printer connected via USB port.
Recently added LaCie backup drive, connected via Firewire 400 port. Printer worked correctly for a while after the installation.
Problem: Prints 'garbage'; looks like printer control text, interpreted as literal text. Sample:
dup 58 /t put
dup 59 /u put
dup 60 /eight put
  • 876 Answers
Http://www.brother-usa.com/Support/?WT.svl=support
You can contact the company for support and also download a manual here if you do not have one. There are alot of support options for your printer here. I can find no reference to the garbage printing and the numbers it is printing.
The only thing that I can suggest is to turn it off, unplug it, disconnect it and let it sit for 1/2 hour to see if it will reset itself. Then I would plug it back in, connect to the computer and restart the computer. Then I would turn the printer back on. Some printers respond well to this simple reset.
Good luck to you and thank you for using FixYA. Ratings are always appreciated.
Posted on Aug 24, 2008
Cannot add r1800 to Leopard
Important OS X pre-installation instructions: The Macintosh OS X driver found on the CD provided with your product is not intended for use with Intel-based Macintosh computers. If you have already installed the OS X printer driver provided on your product CD, please follow these important instructions before installing the "epson11769.dmg" file:
  1. Open the OS X "Printer Setup Utility".
  2. Select the "Printer Setup Utility" tab and click "Reset Printing System...".
  3. Click the "Reset" button.
  4. Restart your computer.
  5. Install the downloaded "epson11769.dmg" file.
Installation instructions (some of the following steps may not be necessary):
  1. Download the file.
  2. Double-click the downloaded file to create a disk image on your desktop.
  3. Open the disk image.
  4. View the included "Readme First.pdf" document for important information.
  5. Double-click the installer icon to begin the installation
link to driver
disconnect usb, delete all old attempts, do not connect untill prompted by install
Dec 04, 2007 | Epson Stylus Photo R1800 InkJet Printer
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
Priner OK with PC but will not print from Photoshop used on iMac
that is a common problem with the new leopard software by now I think they have fix that so try to download the latest drivers if not check your printer settings
Sep 08, 2009 | Epson Stylus Photo R1800 InkJet Printer
Tally 8008 not printing mac OSX 10.5.6 leopard
Found a solution. We connected 8008 printer to imac running Tiger & we can now print via network on any of our emacs running Leopard. Not ideal but at least we can now use the printers. I would still love a dedicated driver to work direct but I suppose this will do for now.
Jan 13, 2009 | TallyGenicom 8008 Laser Printer
HP 3845 Inkjet won't print color under OSX
Try this test:
Let's say you want to print this present page (of fixya.com from Firefox or another web-browser), try File/Print and see if you have the tab Advanced to change to the color cartridge.
Oct 29, 2008 | HP Deskjet 3845 InkJet Printer
Installing hp 3550 printer driver on new OSX leopard system
When I try to print from an access data base to the laserjet color 3500 usb printer.
Tried diff. drivers, diff usb cable, it works for a while but after several test runs the error reapears.
PCL XL error
Subsystem: KERNEL
Error: ColorSpaceMismatch
Operator: VendorUnique
Position: 9
Mar 09, 2008 | HP Color LaserJet 3500 Printer
2 Problems: 1) Unable to get printer to print from desktop; 2) Kodak SW won't install on laptop
Download and install the new software and printer firmware from kodak.com (link below - firmware and software is the same for all the 5000 units). Do not use the CD, and Uninstall all previous versions before installing the new software you download from the site.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?operatingSystem=mac_os_x_10_5_x&downloadLanguage=en
I hope this helps. If you still have problems respond to this message with what happens and I will try and get you more help
SDtester.
Mar 04, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
New Intel MacPro + Epson SP R1800 printer + OSX 10.5.2 = Nightmare.
I managed to solve this problem by, probably, doing what I should've done in the first place: Deleting the printer from the print queue and starting again from scratch.
I read the following instructions from a message from Epson and it pointed me in the right direction. It sounds obvious now, but when you think you've tried everything and you've started to pull your hair out, you can overlook what is staring you in the face.
Message from Epson:
If your output is faint or if the driver settings and/or features are
missing, your system may have automatically added the printer using the
Gutenprint driver. Many Epson drivers are provided with Leopard but the
driver for your printer needs to be downloaded from the Epson website.
Determine Which Driver is Currently Being Used
1. Click on the Apple icon in the upper left corner of the Finder and open
System Preferences.
2. In the System Preferences window, click on Print & Fax.
3. In the list of printers on the left side of the Print & Fax window,
click once on your Epson printer to select it.
4. Check the name of the driver being used; it is displayed in the center
of the Print & Fax window next to “Kind”.
5. If the driver name displayed next to “Kind” is Gutenprint, the incorrect
driver is being used. Follow the steps in the next section to select the
correct driver.
Selecting the Correct Driver
1. Turn off the printer.
2. Delete the print queue and remove the printer from Print & Fax by
clicking on the minus button under the list of printers. Click OK to
confirm the removal.
3. Go to the Epson support website (www.epson.com/support).
4. Select your product model and download the driver for OS X 10.5 Leopard
operating system.
5. Double-click the downloaded file and follow the on-screen instructions
to install the printer driver.
6. Click on the Apple icon in the upper left corner of the Finder and open
System Preferences.
The message ended there.
If anyone out there is having a similar problem to me, then I hope this thread helps.
All the best. logan
Mar 02, 2008 | Epson Stylus Photo R1800 InkJet Printer
Brother HL-2170W Laser Printer Logo
219 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
