Question about Sirius Boombox for Select Satellite Radio Receivers
No sound Model SP-B1a This unit was hooked to a 12V battery but the polarity was reversed. Everything works but there is no sound at all from the boom box. I've opened it up and have the circuit board out hoping to find a blown/burnt diode but everything looks fine. Any clues?
  • redflag600 Aug 24, 2008
    Sorry, I should have said this is a Sirrius boombox I'm reffering to.
    Sergeant:
    Champion:
  • 318 Answers
The polarity was reversed and semiconductors are burnt at the output of the unit.
Posted on Mar 20, 2009
  • bernard lunda
    bernard lunda Mar 20, 2009
    the polarity was reversed and semiconductors are burnt at the output of the unit.
I believe this got hooked up in reverse polarity. It will not work know. Can it be repaired?
Hello Mike,
I believe... the big danger with hooking up batteries in reverse polarity... is the explosive RISK.
It seems you got away with that...
(although it is a VERY good idea to have fresh water & baking soda IMMEDIATELY NEARBY if you do manage to provoke an explosion. Once you are blinded, perforated by battery shrapnel, burned & soaked in ACID you won't be thinking clearly).
Most everything in your car is rated for 12 volts... the POLARITY is only important for magnetic direction... Such as windows going up instead of down... seats going forward when switched to go back... Lights don't care... Diodes and transistors simply won't respond...
With the possible exception of some rather unique POLAR capacitors ... but we know that is really not all that wise... No/yes?
Perhaps now would be time to analyze what the ORIGINAL problem was when the battery got removed, reversed... Make, year, Model... and operational issues... and history...
Just put the battery in correctly (Battery & Ground) ... and start with the BASICS.
FUEL, FIRE & AIR... I would be happy to make more relevant suggestions as you progress... Just comment me back.
Stay safe... work safer...!!
Jan 17, 2016 | Cars & Trucks
How do i connect 4 batteries in series
Here is the way to hook them up in series, or in parallel.
There are 3 batteries in top (series) pic, but a 4th would be added in same wiring manner. Disregard the letters "ve" in diagrams, but the +/- polarity is vitally important in hookup.
Note that four 12v batteries hooked up in series will be 48 volts at the end terminals. (If all four are hooked up in "parallel" then the total would still be 12 volts).
If you want to supply a 12v inverter, you need to hook 12v batteries in PARALLEL.
Nov 01, 2014 | Cobra 2500w Power Inverter
Reverse polarity
Hi Anonymous, drain battery completly buy hooking it up a headlight. It may take a few days but it is the only way, make sure battery has 0.0000 volts before hooking it back up to a trickle or 1 amp charge rate. Good luck
Apr 09, 2014 | Harley Davidson FLHTCUI Electra Glide...
I have an Onan 3600 microquiet lp. I made the mistake of hooking up a jumper box to the battery with the cables crossed,now it blows the 5amp fuse that supplies power for starting. hope I didn't fry...
It certainly sounds like you have damaged the control board. If you cranked it with reverse polarity, there is a good chance that you have rotor winding damage also. If not you still may have to flash the rotor windings to ensure a correct polarized field. That involves hooking a battery for a couple of seconds to the rotor brushes (with correct polarity) with rotor brush wires disconnected. Only do this if there is no output voltage after you replace the control boards. Bad mistake :)
Aug 05, 2013 | Onan Microquiet Generator Lp Vapor 3600...
Golf battery polarity
reversed polarity,check fuses. check the system for burnt wires also !
Always hook up your battery terminals correctly, as the alternator may be damaged if the battery is hooked up backward. jump start car, if it will. there should be at least 13.7 to 14.2 volts at battery posts while its running. if alternator is ok.
Nov 01, 2011 | Cars & Trucks
I have an Icom VHF that was hooked up reverse polarity on 12v.
They likely replaced just about every diode and possibly the main circuit board. The tech should be willing to tell you exactly what work was done, and many return the replaced parts.
Feb 21, 2010 | Radio Communications
Locked up sub-woofer cone won't move?
In theory your idea would work, however you risk damaging your amp by reversing polarity and the positive and negative wires from your head unit are low voltage so they wont provide enough current in reverse or normal polarity to free the cone of your sub. but here is something that you can try that is similar in concept.
Take a positive lead from your head unit and wire it to the negative of your sub. Now ground the positive terminal of your sub to the vehicles chassy using a wire. This creates a 12v-14v reversed polarity current that should be strong enough to (POP) the cone so to speak. hope this helps
Sep 26, 2009 | Jl Audio 12W7 Car Subwoofer
Rear camera to show on screen in reverse? panasonic cq-vd7001u
It sounds like you may not have it wired correctly. When the vehicle is reverse the cam works, but when you shift to any other gear IE: park, drive etc you go to black screen as if no signal. I had basically the same problem on my unit, different unit but...on the back of my unit there was a wire, you probably have the same, that said rear cam 12v dc.I assumed this meant any positive wire would do, but this is NOT the case. That wire must be hooked to the 12v positive reverse light. With my cam I had the wires from the cam hooked up, red to positive reverse light wire, black to ground and obviously video wire to the video in on the unit. but the problem arose with that rear cam 12v dc wire on the back of the unit. It NEEDS to be connected to the same 12v dc wire as the cam itself. This acts as a 'switch' when in reverse, IE: the reverse lights come on sending power to the wires to turn on the cam. When you're not in reverse the camera 'switches off' because the lights are not on, thus no power is being sent to the wires, thus returning the unit to its normal operating screen. This worked for me, hope it helps. Good Luck.
Feb 18, 2009 | Panasonic CQ-VD7001U Car DVD Player
Sirius Boombox for Select  Satellite Radio Receivers Logo
124 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
