Question about Husqvarna Rose
Uneven & bunching stitches
I am very disappointed with the Rose that I purchased as a demo machine. It has never made even spaced / length stitches. I took it back to the dealer who had it looked at and said that it should work okay, but it doesn't. I have invested over $2400. in this machine along with the 3D Embroidery program. I can't begin to dream of using the embroidery program when it doesn't even make a consistant straight stitch. How in the world will I ever be able to use this thing? I am beyond frustrated and nearing hopelessness with Husqvarna products. I need a machine that works properly, how can I get the help I need?
  • 3 Answers
Where are you - someone may know someone in your area that can help.
Stephanie
Posted on Sep 06, 2008
Stitch is uneven
Change needle is always Rule #1
Mar 23, 2014 | Elna Sewing Machines
My stitch becomes very small when I sew fast, even when the stitch length is 3.5.
it sounds like the machine either needs some adjustments done
or the timing checked by a sewing machine shop
Dec 20, 2012 | Husqvarna Rose
Stitches are uneven
my hard ware lock is not working
Dec 27, 2011 | Bernina Artista 180
VIK ROSE 45010050 Stitch size button will go up but not down in size...
Possibly the touch pad is bad. Are they any other buttons that don't work? Usually when the touch pad is bad other buttons won't work either. If only the stitch length won't work then the step motor for the feed is bad or you have a bad board.
Apr 20, 2011 | Husqvarna Rose
What settings for doing zig zag for satin stitch around applique. I have used 3.5 width and 0.2 length but the fabric has a tendancy to pucker and the stitches sometimes bunch
It depends on a couple of things. Depending on the fabric you're using you might want to use a stabilizer like an iron on tear away. If the stitches are bunching the stitch length might be to tight. Try going to 0.3. if the stabilizer doesn't work. With the stabilizer on, it will keep the fabric firmer so it won't pucker. Make sure you have the decorative stitching foot on the machine with the little indentation for the satin stitch to ride in. If you have the wrong foot on, this will cause bunching too. Let me know if this helps.
Aug 22, 2010 | Janome Memory Craft 4900QC Mechanical...
Topand bottom stitches are not even
Could be a tension issue.
Try this to see if it helps:
Remove top thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Start the top tension set at the midway point and then adjust.
Check that the bobbin is threaded and installed correctly.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Apr 22, 2017 | Singer 7436 - INGENUITY
Problem with Brother XL-3750
can u chart me on whatsapp +2348189956612 so that i can help.
Oct 03, 2017 | Brother XL3750 Mechanical Sewing Machine
Husqvarna rose
2 things to check first:
1. Make sure the feed dog "switch" is in the correct position. It is located under the free arm, directly under the needle plate area.
2. Make sure your stitch length knob is in a position OUTSIDE of the orange reverse stitch positions.
Nov 25, 2007 | Husqvarna Rose
Sewing Machines Logo
82 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
