Question about Kenwood KAC-9102D Car Audio Amplifier
Install my Kenwood KAC-9102D in my 2006 Acura RSX Type S
I want to install my Kenwood KAC-9102D in my 2006 Acura RSX Type S with the Bose factory system radio. It has a small sub base and want to use my Kicker L5. We ran power from the battery and the continues power from under the wiring harness under the passenger's seat. Re ran the wires from the existing sub and used an RCA jack to the input on the amp. If we use the RCA output back to the Kicker sub is has very little power. It we use the output + & - we do not have any output from the spearker.
  • 631 Answers
You will probably need to use a Line Output Converter (LOC). They're available at virtually any shop that sells car audio.
Many times, the outputs of the OEM amplifier will have significant DC voltage on them. This could damage the input circuits on the kenwood amplifier.
Let me know if you have any other questions.
Posted on Aug 25, 2008
Wiring options
Yor best bet is to wire each one positive to neg to get 8ohms then pos-pos and neg-neg to get 2.66 ohms. Otherwise series parallel. If you wire them all pos-pos and neg-neg you will be running .66ohms and will most certainly fry your amp or it will overheat and shut down all the time
Sep 07, 2009 | Kenwood KAC-9102D Car Audio Amplifier
HAVE A KENWOOD AMP MODEL KAC-9102D . iT KEEPS SHUTTING OFF WHEN i TURN THE RADIO LOUD. ANY SUGGESTIONS
either bad ohm load or over heat if the ohs on the speaker wires to the amp are lower than specified use in the manual it will act funny cause it is pusing harder than its meant to and if it gets too hot either bad location or bad amp you can try turning the gain down a little until the amp stays on constantly at high volume
May 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Running 2 amps
amps could be overheating or the subs could be requiring more power then the amps are giving off.
Apr 01, 2009 | Kenwood KAC-8452 Car Audio Amplifier
1 amp cuts off
i had this same prob. & i run 2 amps as well, cameto find out i had a neg. & positive touching , so check all ur wiring for tht amp..
Apr 01, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
KAC-9102d no sound, Amp powers on but no sound to the subs.
If the sub isn't working, you won't get a pop. All you need is a small speaker. Don't need a sub, you just want to test the sound. I recently blew 2 subs, no smoke, no smell, no sign of being blown. Absolutely nothing from the subs.... In the past my sub locked up. You can take your sub out of the box and hook the + and - to the battery to see if you can get the sub to pop there. I believe a small box will push a sub into a deep excursion to the center of the cone. I have 2 lanzar VW12D's that just quit. I hooked a 6 x 9 up to my amp and low and behold I had sound! Try that and see what you get...
Feb 07, 2009 | Kenwood KAC-9102D Car Audio Amplifier
How to install kenwood kac-9102d in 2006 acura rsx
My recommendation is to get a line level converter. Go to a car audio shop or even best buy and specifically ask for a line level converter. It will have speaker wires in and RCAs out. Connect the speaker wires to the sub woofer speaker wires and then you will have the RCAs to run to your amp. I hope this helped.
-Andrew Hawkins
Aug 24, 2008 | Kenwood Car Audio & Video
Wiring
hi!well i think you should use both channels.because if you'll use both channels then u'll have high power to your subs.i have tryed it and i prefer you use both channels.
Jun 26, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Will it work together
put a the amp the max charge permitted, and y you have a preamp you can makeit work.
Feb 10, 2007 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier Logo
302 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
