Question about Panasonic Videoprojector PT-LM1E Multimedia Projector
Panasonic projector pt-lm2e
I have blue patches on the screen. what does this mean? Is it my bulb going or something that needs to be fixed
  • Anonymous Dec 31, 2008
    • I have a panasonic Projector (PT-AE700U) and there are patches of blue on our screen. Not sure if the bulb is going. Bulb is only 4 months only
I have Panasonic Pt-LM2E projector and it have a pblm,when it goes standby mode after some time (5-7minutes).no other indications shown (eg: lamp,temperature ).pls give a solution for this
Regards
Siva
Posted on Jun 28, 2010
  • 22 Answers
If the bulb is new & clean. It could likely be the connection between your video source (computer, tv. etc). Try reconnecting or getting a new cable before costly repairs.
Posted on Jan 09, 2009
    New Friend:
I have the same problems with my Panasonic PT-LM2E, the blue specks on the bottom of the screen, midway across the screen. I checked the air filter and discovered that it had started to disintergrate inside the machine and as a result, bits of fine particals had been sucked into the "LCD" blower fans located on both sides of the lens.I disassemble the cooling unit and found that pieces of air filter were on the Lcd colour filters and the Lcd block. I also found that a piece of air filter had lodged itself in the fan scroll causing it to run out of balance and crack the fan scroll. I'll try and clean the filters with low pressure compessed air and see if it makes a difference, however replacing a blower fan is going to be a hard. Bulb has 1760hrs on it,the projector was purchased in 2005, so now its a question of "Is it Worth try to Fix It.
Posted on Jan 28, 2013
All issues like this are usually due to dirt within the lens unit/ LCD module. Carefully stripping the projector and cleaning of all lenses could solve this problem. However if the LCD unit is too badly damaged, colour staining will still occur.
Posted on Jan 08, 2012
How to reset the panasonic PT-L702ES LCD PROJECTOR after changing it bulb ET-LA702
How to reset timer on PT-L702E LCD PROJECTOR:1. Power on the projector and go into the menu
2. Go to OPTIONS > LAMP TIMER
3. Press and Hold ENTER for at least 2sec - message will change to something like 'Power Off to reset timer'
4. Press POWER to power off projector
5. Power projector back on
The timer has now been reset to Zero Hours
Enjoy!
Sep 21, 2011 | Teac Panasonic Etla702 Replacement Bulb (...
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
Our projector (Panasonic PT AE900U) is still working but the picture seems very dark all of a sudden. we are wondering if this means we need to replace the bulb and if so, what do we replace it with.
You need a new lamp. Cost is around $350. The following site shows replacement:
http://www.shopvsc.com/Replacement-Lamps-for-Panasonic-Projectors-s/284.htm?searching=Y&sort=7&cat=284&show=50&page=1&f-PT-AE900=109462
Oct 16, 2010 | Panasonic (ETLAE900) Projector Lamp for...
PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
I have a panasonic pt l500u, just started getting large yellow spot in middle of screen- looks like a giant finger print. Bulb was replaced less than two months ago.
Hi:
The problem here is the one of the miniature LCD screens in the unit is faulty, in this case its the blue one. There are three of them inside the unit RED<GRN<BLUE. The blue seems to be failing in your unit, for instance if you mix red and green you get yellow. Have a local shop service the unit and clean and refocus the unit back to factory spec's..
Nov 04, 2009 | Panasonic PT-AX200U Projector
PT-AE700E projector appears to have gone kaput - not lighting up.
Because of high voltages and heat, there are many safety circuits inside these units. If you have a spare lamp, try replacing the lamp. Initial checks are made before the lamp is fired and sometimes a defective lamp can cause this. Also, can you descruibe what you mean by "noisier than usual"? Is the fan making more noise? Something elase making a noise?
Thanks,
Dan
Oct 15, 2009 | Panasonic PT-AE700U Multimedia Projector
Blue Haze on the left and various other places on screen
it's the polarizing filter on one of the lcds. they tend to fry due to excessive heat. clean the dust out of the projector so it can cool down properly. but you will need to replace that filter. it is fairly easy, but remember which plugs go where. however, many companies won't sell parts for or replace components of the optical engine or the prism assembly. if they don't, it's going to cost a bit. check the panasonic website for the closest authorized service center.
Aug 28, 2009 | Panasonic PT-AE700U Multimedia Projector
PT L711U + all my black colors are blue
Your projector needs to be aligned and serviced, normal occurrence
after 6 years since service.
Apr 18, 2009 | Panasonic PT L711U Multimedia Projector
Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Nov 04, 2008 | Panasonic PT-AE700U Multimedia Projector
Growing blue patch
you have to replace prism it has 3 small lcd screens Green Red Blue one of them is beginning to burn they are very expensive strip projector down with no power connected and take damaged screen of then block that area so no light can pass through it with fire resistent material you will get some more life out of it
Aug 11, 2007 | Hitachi PJTX100 Multimedia Projector
Panasonic Videoprojector PT-LM1E Multimedia Projector Logo
661 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
