Question about Traulsen 46 cu. ft. Commercial Freezer G22001
Traulsen GLT232NUT double door freezer
Does not get 115v on both fans therefore cabinet will not cool down as it should
    Novelist:
  • 124 Answers
Since this is a commercial box it is possible the second fan kicks in only when the coil temp gets down to a certain temp. this cuts down on snow development . you can look at the wiring to the fans and trace it back to whenre it comes into the blower area . does it go directly to fan a then to fan b? if so verify the voltage is getting to the motor. if it is then the motor is bad.if the power loops through a temp sensor it is possible the second fan doesn't energize till the coil temp is down to freezing. if you see no break in the incoming power to both motors then the motor itself is probably bad. it may be possible to switch power leads from running motor to non running motor. if you do and the bad motor runs the you've got a bad power lead to the motor. good luck.
Posted on Oct 26, 2008
  • Karen Duncan Oct 26, 2008
    if you have a refrigeration problem like low charge or in efficient compressor the coil will never get cold enough to activate the second fan. in the old days we would find the temp sensor and blast it with some liquid refrigerant, duplicating the cold coil. a sign of low ref charge is ice formation particularly on incoming feeder lines into coil, the small lines usually real tiny.if there is a sensor for fan it is usually clamped to a pipe in the coil or screwed to the bulkhead of the coil.
  • 639 Answers
Hi palmer
Happy to help you!!
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
Stops cooling unplug replug starts up again
Hello Tana - Freezer might be experiencing some form of sealed system issue or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evaporator fan, coil or coolant lines. Trying checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
Oct 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My frigidaire freezer model FFC13C3AW0 runs but will not cool
Hello - From what you have described it sounds like you might be experiencing some form of sealed system issue or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Trying checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
Sep 22, 2012 | Frigidaire 13 cu. ft. / 368 liter Chest...
My service man replaced the defrost cycle timer and the relay (timer was definitely broken, relay was highly suspect) but the freezer fan still has no power so freezer will not chill adequately despite...
Most all commercial freezers have a fan delay/ defrost terminator. It is usually mounted on the end of the evap coil. It's purpose is to sense the temp of the coil during the defrost cycle. When it hits a preset temp., usually around 55 degrees or more (depends on Mfg.) It terminates the defrost cycle. It also doubles as a fan delay. It allows the evap coil to cool off from the defrost cycle before allowing the fan to come on. Usually, the coil has to get around 20 degrees before fan will energize. I would look for this as a possible problem. It could be one device with 3 wires or 2 separate devices with 2 wires each. I've seen it both ways.
Hope this helps.
Nov 19, 2009 | Traulsen 46 cu. ft. Commercial Freezer...
Our Traulsen Freezer will not hold the cooling agent.
Have someone out to do a nitrogen leak check on it. Sounds like a leak needs to be found and fixed. Hard to find leaks can be spotted by adding UV dye to the system.
Aug 31, 2009 | Traulsen Freezer G31010 Solid Door...
Freezer wont cool
This problem could be cause by a few things. Can you tell me if your condenser is clean? If it is dirty, the heat cannot be rejected. Will you feel the large copper line going to the compressor and tell me if it is cold to the touch? If it is not col and your compressor is running you may be low on refrigerant. Also, is the evaporator frozen over? If your evaporator is frozen over you might be low on refrigerant, or you evap fans may be out.
Feb 15, 2009 | Traulsen Freezer G22013 Freezer, Reach-in,...
Traulsen GLT232NUT which is now G22010
check for a good neutral. Sounds like that's the place to start. Check from the unit to the breaker.
let me know if I can be of any further help.
Aug 25, 2008 | Traulsen Reach in Freezer - G22010
Commercial Freezers
I have worked in a lot of kitchens and don't really have a preferance. The top mounted compressor is better for you as it is easier to service and leaves more cabinet room. Dirt and dust also stay near the floor. YOu won't have to clean the filter as often up high The disadvantage to this in a kitchen is that kitchens are hot and up high is hotter still. Order a cheaper model. No glass doors, no stainless steel. You don't need these features.
Jun 24, 2008 | Traulsen 7 cu. ft. / 198 liter Commercial...
Traulsen 46 cu. ft. Commercial Freezer G22001 Logo
330 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
