WHEN I DEPRESS THE SCAN BUTTON IT SHOWS A IMAGE TRANSFER PENDING MESSAGE IF I RE-START THE COMP. IT SCANS ONCE W/O PROBLEM
Okay , You can scan once. Then close the scanner monitor controls. Then START-Programs-Paperport-Scanner Monitor. This reopens scanner Monitor for next scan. You may also have to START-Run- then type in %Temp%. Go to the One Touch folder to get your pics and delete all files before you scan another pic.
I'm having the same problem with my Visioneer OneTouch 5800 USB. I'm running it on my XP with SP3. What is your configuration?
I am having the same problem with One Touch 8700
I am having the same problem. Re-starting the scanning software every time is not an acceptable solution.
