Question about Kitchen Ranges
I just bought a firenzo FDO900 2nd hand it doesnt come with any manuals and the wires on the back aren't connected any chance you know where i can get a manual from or know how to fix it
  • 639 Answers
Hi Ed,
Happy to help you!
Go online to the manufacturer and try downloading the manual.
There are other sites to acquire manuals too!
I think that this problem will be solved only by service!
You can try these guys first!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Posted on Aug 25, 2008
Can i set this amp by hand, stereo shop cant get it sounding right, sloppy and distorted bass doesnt go very loud, mids and highs arent quite right either please tell me how to set this right
If it is new, take it back. If you bought it second hand, you know why they were selling it. Probably been wrongly wired and damaged or it has been damaged by too high volume levels.
The only way to fix properly would be to return it to the manufacturer.
Of course the other possibility is that your speakers are not compatible (impedance), or they are damaged.
May 03, 2016 | Car Audio & Video
Our dryer wont start and the outlet doesnt give us power. The circuit breaker works until we plug the dryer in. Please help
most likely the heating element is shorting out or a wire is touching metal in the dryer or you have a problem with the house electrical,unplug it,pull it out and remove the vent line and the back panel,first check the connections where the cord connects to the dryer and make sure that's ok.if that looks fine go to the heating element connections down on the bottom right hand side,pull off the wires going to the element,check the element with a meter or make sure the wires aren't touching anything and plug it back in,if the fuse doesn't pop change out the heater,if it does pop again call an electrician to check the house circuit or and go through the dryer to see if any of the wires are shorting out,
Sep 22, 2011 | Whirlpool LER4634J Electric Dryer
I just bought a 2003 grand am gt and noticed when i back up reverse lights aren't working any suggestions
Hi, first check fuse 42 in the fuse box under the hood. If the fuse is good, the problem is in the switch or the wiring. You can test the switch by pulling the connector off and connecting the terminals inside using a paper clip. With the key on, connect the pink and light green wires. If this turns the backup lights on, replace the switch. If the light do not come on by jumping the connecter, you will have to trace the wiring to see where it is broken. If the pink wire is hot with the key on, the break in the wiring is between the switch and the back of the car. If the pink wire is not hot with the key on, the break is between the fuse box and the switch. Assuming you have an automatic transmission, I have pasted a picture of the switch below. It is mounted on the transmission. If you replace the switch, make sure you adjust the new switch before fully tightening the screws by leaving the transmission in reverse (engine off, key on) and turning the switch while watching to see when the lights come on. Please let me know if you have questions, and thanks for using FixYa.
Jul 30, 2011 | Pontiac Grand Am Cars & Trucks
My friend bought a second hand kia sportage 4x4 2001 model. The radiadtor fan doesnt work. does this model have an electric fan or is there a fan belt that drives it. The car at the moment has an electric...
if previous owner bypassed the switch and hot wired the relay then he done it for a reason like its not working or the engine overheats ,make sure you have a 50% antifreeze coolant inside the rad and leave well alone ,what happens is you get people buy a new vehicle then they listen to bar room mechanics that know it all and the favourite one is to drain antifreeze in the summer so engine runs cooler ,what they do not know is that this causes the internal water jackets to corrode ,then when they get a problem they sell motor quick ,or they get a new company car every year .Yes these bar room know it alls live in every country and the the more they knock back the more know it all ,worst places? local brit clubs abroard where a stiff upper lip accent and slowly spoken means one is intelligent ,Trust me on this
May 02, 2011 | 2000 Kia Sportage
Need a pic of wiring up to my van as some idio cut most the things off before i bought it,,,, iv got the sony cdx s2200 i want to put in.
The best advise I can give is to use the connection that you baught and cut of the end that connects to your VAN then you need to isolate the correct leads from your car. The chances are that they wont be the same colour so if you can get your hands on a voltmeter you should be able to find the correct leads. The manual for the stereo should tell you the correct colour wires for the head unit red=live black=neg.
Additionally, send us details about brand, year and model of your VAN, could be there some wiring diagram.
Keep in touch.
Apr 06, 2011 | Sony CDX-S2200 CD Player
Guitar hero world tour xbox 360
The guitar syncs the same was a regular controller does.
There's a tiny sync button near the XBox button on the guitar. Press that, and then the sync button on your Console.
Apr 09, 2009 | Buck Guitar Hero World Tour for for Xbox...
Wii doesnt turn on
Okay, I had this problem also, it made me freak out, considering it was only 1 week old! what I did, and it worked, is
1. unplug every wire connected to the system (wires to/from wall, to sensor bar, and to/from TV)
2. unplug every other thing connected to it (i.e. memory cards, older controlers, etc...)
3. let it stand off in the dark for a couple of minutes (I reccomend 5 minutes or so)
4. plug the wires back in
5. turn it on
6. put anything else back in (i.e. the memory card)
If that doesn't work, or if this keeps happening, I reccomend bringing it back to the place you bought it (Walmart, Best Buy, Circuit City, etc)
, b/c they can give you a new one, or your money back. However, the warrenty could expire, or not even exist if you bought it online, or if you've had it too long.
I hope I helped you!
-Tori Toothpaste
Jan 03, 2009 | Nintendo Wii Console
Storing channels and time display
* Connect Yellow wire to continues power ( it is back-up power to memory circuit)
* Connect Red wire to switched power
You can download User Manual and Installation Guide for CDX-S2000 from Sony Support for more information.
Oct 23, 2008 | Sony CDX-S2000 CD Player
Replaced motherboard
If you can find out the make and model number of the motherboard inside you can look on the net for the manual (or let me know and I will look for you), which tells you where everything goes. The make and model number is usually printed on the board.
Mar 18, 2008 | Mercury P4VM800M7 Motherboard
I lost my manual on hooking up the wiring on my nforce3-a motherboard.
Chances are, you can download the manual from the website of the manufacturer. That's probably the smart move. Last thing you want to do is try and do connections without it. That's a quick way to go through more than one.
JD
Digital Advisor
Dec 01, 2007 | EliteGroup nForce3-A Motherboard
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
