Question about Sanyo VPC-CG6 Digital Camera
Taking flash pictures with Sanyo cg6 camera
Can a stronger flash be used with this camera in order to take pcitures from a greater distance than 6 feet??
    Champion:
  • 203 Answers
Best buy sells a bracket that mounts on tripod screw on botom and then you can also buy a stronger flash in same area that will mount onto bracket
Posted on Aug 25, 2008
How do I down load pictures from my camera to the PC. Sometimes I get it to work and other times nothing happens. Thank you.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Nov 02, 2010 | Sanyo VPC-CG6 Digital Camera
Same as posted - picture is way too dark when using flash. Help!
Try a camera reset. Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
Sep 23, 2009 | Canon PowerShot A630 Digital Camera
Camera got run over-where can I send it to get it fixed?
I would call your local camera shop to see if they can give you a quote over the phone to fix.
Jan 22, 2009 | Sanyo Xacti E6 Digital Camera
I cannot transfer videos to my computer with my Sanyo Xacti VPC-CG6
After the USB cord is connected, a menu will popup on the camera. The camera needs to be told you want to transfer files with the usb rather than use the camera as a webcam for example.
Selecting USB Connection / Card Reader on the camera should allow you to access your files on the camera.
You could try removing the memory card from the camera and using an external usb card reader on it.
Oct 07, 2008 | Sanyo VPC-CG6 Digital Camera
Driver sanyo vpc cg6
When the Sanyo CG6 is plugged into the computer, and the popup menus on the camera are directed to USB Card Reader Mode, you should not require any drivers for Windows or MacOS.
Review the CG6 Users Manual for more information.
Jul 03, 2008 | Sanyo VPC-CG6 Digital Camera
Changing the language
The CG6 manual states how to find the change language option in the menus on page 135. Even though you can't read the characters, the position on the menus should be the same.
Dec 23, 2007 | Sanyo VPC-CG6 Digital Camera
Random Pictures?!??!
look for a small opening to insert a pin. many companies offer this hole as a way to reset the micro-controller. insert the pin during power up
May 07, 2007 | Sanyo VPC- C6 Digital Camera
Metz 6ct4 flash head
Are you still having problem with the flash not flashing? Use a DVM (digital volt meter) to measure the battery from the pack. Take the 6 volt battery out from the pack and measure it. A reading of 6vdc or greater is good. Also the for amp. of the battery. Alexander atdlee@netzero.com
Apr 05, 2007 | Metz Mecablitz 60CT4 TTL Flash
Sanyo VPC-CG6 Digital Camera Logo
61 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
