Question about Dishwashers
I can't find the filter on GE Triton dishwasher to clean it. Also, where do I add the dishwasher salt?
  • thesimps Aug 24, 2008
    I have the same problem. And, my dishwasher is not draining. Not able to find anything in hoses connected to dishwasher. Thinking it must be filter(s) is dirty. I don't know where to check the filter either.
  • Anonymous Mar 25, 2014
    i need to add salt to my dishwasher
  • 706 Answers
If possible, can you provide the specific model of your dishwasher? ( That would help) also: see attached link to a site that shows pictures of generic GE dishwasher pumps.. at least one view shows a screen on the inlet of the pump however many dishwashers have a screen that traps food particles from draining into the pump and I would look at the loweset point inside the d/w itself for a drain opening. Some mfrs put a screen filter there..Could be more specific if you could provide model numbers though.. Hope this helps..
Posted on Aug 24, 2008
I have a GE Eterna Series Triton XL. It is not cleaning the dishes very well. The top dishes (glasses & mugs have debris in them. Silverware not very clean either. Can you help. I have checked the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 01, 2010 | GE Dishwashers
,seems as though washing tablet dos not desolve during wash leaving glass with a coating off powder on them,filters have been cleaned
John, clean filters, add salt and rince aid and buy a bottle of dishwasher cleaner and run the cycle on the 70degree setting. Good luck!
Aug 11, 2010 | Zanussi Dishwashers
GE Triton 24
Hi
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please post back for any further assistance.
Daniel
Jul 23, 2010 | GE Dishwashers
My GE Triton XLdishwasher, model GSD6300 Gooww is leaving a
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 15, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
My GE triton dishwasher has water standing in the
The GE GSD5500 has a check valve in the rear of the unit under the FILTER FRAME that screws in. GE part WD24X10018.
The white rubber stopper wears out and lets water return to the tub!
Remove filter frame (4 screws) and unscrew the check valve to replace. Try appliancepartspros.com for part # AP2617344.
Nov 30, 2009 | GE Dishwashers
My ge triton xl dishwasher isn't getting are dishes clean. There is a white film on the glasses and I find dark spots on my plates. There is always dish soap left behind in the dish soap container. It was...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishes are cloudy and covered with a film when done
Refill your SALT container with 1kg of dishwasher salt.
Salt reduces hardness in water -and increases cleaning efficiency. If you have a little furr build up in your kettle - you need salt in your dishwasher to work properly.
If you do use salt, it may be the salt reservoir is blocked with caked salt.
Oct 02, 2009 | GE 24 in. GSD4000J Built-in Dishwasher
Dishes not completely clean or rinsed, and mold
get some dishwasher salts and unscrew the cap at the bottom of the dishwasher empty the filters and run the cycle. fill up the water with dishwasher salts in the white unscrewable cap put about two cup fulls in.there it should work better then. there is also a product called rinse add you can by this from the local supermarket. hope this helps
Mar 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Miele Dishwasher G856 SC cleaning assistance
Yes run a cycle with 2 cups of vinegar to flush it out
Mar 15, 2008 | Dishwashers
Dishwashers Logo
261 people viewed this question
Top Dishwashers Experts
