Question about RCA D52130 52" Rear Projection Television
TV turns self off during watching, also has darkened picture.
I was recently given an older D52130 with a problem. During any use, the TV turns off after 20 - 30 mins and won't come back on for about 20 - 30 mins. When I try to turn the TV on during this period, it makes a click sound. After it's presumably cooled down, it will work again for another 20 - 30 mins.
Additionally, the picture looks darkened compared to what I would expect it to be. I read about a 27k resistor I should replace but haven't yet gotten that done. I am definitely considering opening it up and vacuuming out the components to get rid of dust. Are there any components I should avoid with the vacuum?
Lastly, I don't have the manual for this TV and would like to get a pdf copy somewhere. I checked RCA's website but couldn't find anything for this model. Anybody got a url?
  • 2 more comments
  • Chris White Aug 25, 2008
    I vacuumed the TV components last nite and when I turned it on, the TV ran for 3 hours before shutting itself off again. This morning, another 30 mins and now it won't turn on anymore. I hear 4 clicks and see the power light flash 4 times but the lamps never kick on.
    Please help, if anyone knows of a solution to this problem, would you kindly share?!
    Thanks,
    SlaeYer
  • Chris White Aug 27, 2008
    Maanita, I should have clarified earlier, this was done many times by the previous owner as well as myself yet it's not something a reset will repair.
    I'm electronically savvy, and know how to solder on PCBs, if needed to replace components. Additionally, I've got a multi-meter and I know how to use it if anybody could give me an idea of what values to look for.
    Google searches yield no helpful results, this is driving me insane!!
    Thank you
  • Chris White Aug 28, 2008
    This TV was unplugged for 2 years. I did try your suggestion anyway, but no change. Please help.
  • Chris White Aug 30, 2008
    Thanks for the link to the user manual.... any ideas on the other problem?
  • 1,183 Answers
In case you are comfortable with the internals for the TV , try checking the board on the following points
Check the secondary of T14600
Also check for short circuits on CR14611, CR14609, CR14608, CR14607, or CR14602. Q14601(G) Q14601(D)
Do static checks around the soft start circuit
There could be a probelm on the R14618 a 680K 1/2 watt resistor.
Thanks
Proton
Posted on Aug 30, 2008
  • Mandeep  Singh
    Mandeep Singh Aug 30, 2008
    The protection system on the RCA sets hides the clues to a tech such that the only way to get at the section that is causing the trouble is to defeat the protection circuit and start taking measurements of the many sections within the tv. Sometimes it is obvious and sometimes requires deep investigation.
    Common failures inlude loss of high voltage, horizontal output circuit breakdowns, power supply failures and convergence IC burnouts. In all cases the repairs will run from about $200 on the low side to $400 on the high side
    Genius:
  • 1,269 Answers
Replacing a faulty IC will fix it. Normally, that kind of problem is leads to a shorted power supply chip. Check on the manual where the power supply chip is and double check if it's been burned. In addition, check any bloated capacitor and resistor. Just replace those if you found one. Vacuuming the tv wont help, you need to thoroughly search for broken/burned components.
    President:
  • 1,263 Answers
When you vaccum the dust out you have to remember that static electricity is harmful to the circuit boards it doesn't take very much to short a circuit. it seems that the unit is overheating and inorder to find the part you have to have the tv on and feel which solid state part is very hot.
Posted on Aug 28, 2008
  • Ronald Mueller
    Ronald Mueller Aug 30, 2008
    are the cooling fans operating like they should?
  • Ronald Mueller
    if they are for some reason the heat won't dissapate and the tv will go in self protect mode. chances are *********** board has a chip or 2 that is causing this i don't know the value of the chips you have. but it seems that replacement of the chip/s or board it's self is required.
    Brigadier General:
  • 3,614 Answers
Try to check the resistor on the video output module, and check also for any bad soldered on each parts.
thank you
    Master:
  • 521 Answers
Power supply board gone short.donot on the tv till it is repaired or the other components will also go short.take it to the repair center.urgently.
pls do rate the solution
thanks.
regards.
fixya expert team
  • RCA Master
  • 6,487 Answers
Go to this link for the usermanual http://www.retrevo.com/support/RCA-D52130-TVs-manual/id/402bh427/t/2/
Hope that helps..........
Posted on Aug 27, 2008
  • Mark Gil
    Mark Gil Aug 30, 2008
    No problem, this problem needs further diagnosis so we can really tell what is the problem so we can also give you the correct solution...
    Genius:
  • 1,142 Answers
Do a hard reset to the unit, unplug the unit for at least 2 hrs and then turn it back on it should work fine.
The screen flickers and darkens while watching the TV. It is a 3 month old Bush DLED32165HD. Adjusting contrast/brightness/sharpness makes no difference. Turning off the TV and turning it on again, th
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 14, 2015 | Bush Televison & Video
RCA TV older big back 36" went out during power outage storm, back on with good volume but pictur only a thin line in middle of screen across
People are giving away their older TV's as they upgrade to new wide flat-screens nowadays. That makes your TV not worth fixing. Keep checking Craigslist and your local thrift stores for one that's cheap or being given away.
Jan 03, 2015 | Televison & Video
Why does my insignia turn off buy it self?
There are many reasons for this. If the set turned OFF while watching a program, the power supply regulator board should be checked.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 27, 2014 | Insignia Televison & Video
Vizio M470NV just purchased, while watching TV it turns off with the Vizio light blinking between orange and white. Can not turn back on !! I have to just wait for about a minute then tv turns back on by...
I have the same issue on my Vizio M470NV. I called Vizio and they told me it is a self diagnostic test that is shutting down the TV automatically to protect it. They said they are working on fixing the issue with a firmware update that will be pushed out automatically if you are connected to the internet. No ETA given on when that would happen. I called them on the 3/14/11 and my TV is still shutting down randomly.
Mar 18, 2011 | Televison & Video
I was recently given an older 32" TV. I want to
Radioshack always have something for problems like this.
You need an RF Modulator..
It's very simple and self explanatory.
Jan 19, 2011 | Sony Playstation 3 (PS3) Console
Sometimes has green tint.
YOU ARE 100% CORRECT it is the cameras ....... as a tv camera wears out green is the last to get weak . so the picture turns green crt tvs do the same thing
Mar 25, 2009 | Sony Televison & Video
Rca mm52110 rear projection tv with issues
Will power up, but won't have a picture. What could cause this?
Sep 16, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
I have sound but no picture?
i setup a remote code on the remote so the tv goes on /off and the volume but no picture on screen how when i put the dvd player i can see the movie but noy regular tv please help
May 08, 2008 | RCA D52130 52" Rear Projection Television
Hitachi 51G500A picture adjustments
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence and other adjustments of many popular brad PTVs are given in detail.
Jun 04, 2017 | Hitachi Televison & Video
Tv shuts off while watching
replace EHT (extra high tension) transformer
Feb 07, 2007 | Philips TS3661C 36" TV
RCA D52130 52" Rear Projection Television Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
