Question about HP LaserJet 3050 All-In-One Printer
I have installed a replacement ink cartridge and the printer is not recognizing it. I have installed new printer cartridge, but printer does not recognize it and sends print cartridge missing message.
  • HP Master
  • 19,396 Answers
Remove cartridge and put it back in place.
Posted on Aug 24, 2008
  • Ginko
    Ginko Aug 24, 2008
    Try the following procedure
    1. Remove cartridges
    2. Unplug printer USB
    3. Unplug printer power cable
    4. Wait ten minutes
    5. Plug back printer
    6. Install cartridges back
    If it does not work it can be a faulty cartridge, see if you get same error with different cartridge.
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
My new pixma canon ip 2770 cannot recognize the black and colored ink
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Hi. My printer will not recognize the magenta ink. I tried replacing it with 3 different new ink cartridges, but when I try to make the printer charge the new ink, it does nothing and says I'm out of...
Hi
Some ink printer had ink resetter and just go to ink set up.
If your printer have ink resetter, do it otherwise it will not recognized new ink installed.
If not, some new ink cartridge when the tape is remove, there are cases that the sticky leaf on the ink cartridge, just rinse it with warm water or alcohol to detect the ink cartridge. Turn off your printer and your computer. Then return the ink and open your printer and computer to print again.
Note : Use only ink that is compatible with your printer because it you use other cartridge it will damage the chip set of your printer and it will not recognized any cartridge at all. SO beware.
I hope it helps you.
Jan 12, 2011 | Epson Stylus Photo R1800 InkJet Printer
Hp printer model A909a indicated new ink cartridge needed. When I installed new cartridge kept giving message needed new cartridge. When I removed new cartridge ink was leaking on outside edge of...
Follow the instructions below to replace the printheads in the All-in-One product.
Video of replacing the printhead
The following video demonstrates how to replace the cartridges and the printhead. You do not necessarily need to replace the cartridges. Simply refer to the video for replacing the printhead, and then stop the video.
Aug 28, 2010 | HP Office Equipment & Supplies
I replaced the ink cartridge with a new one, and the printer does not recognize it. Will not print. I opened a second new ink and installed it, but still no recognition. Help!
Sometimes ink will get on the contacts in the ink cartridge cradle causing the cartridge to not be recognized. Use a cotton swab with a little bit of alcohol to clean the excess ink from the contacts where the ink cartridge plugs in.
If this doesn't fix your problem, it's time for a new printer.
Jan 13, 2010 | HP DeskJet 6122 InkJet Printer
My ESP 7 printer will not accept that a new black ink cartridge has been inserted. I've tried 2 new ones, same with both.
Black ink cartridge is not recognized. I installed a new cartridge last week and had no problems printing till 2 days ago. What can I do to resolve this?
Sep 13, 2009 | Office Equipment & Supplies
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
I have installed a replacement ink cartridge and the printer is not recognizing it. Same problem, replacing ink cartridge but not recognized.
Oftentimes you must do a self cleaning plus realignment with newly installed ink cartridges. Try to locate the manual on performing these tests and it should get you started. Also, look to see if your new package came with a self cleaning kit to clean the heads on the cartridge, but be careful not to damage the parts -which are sensitive. Hope this helps
May 27, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
New Magenta Ink is not recognized after installed
Hi, it sounds that the issue can be caused by a defective ink cartridge that installed or a printhead that can recognize magenta ink cartridge. To identify which causes this issue please try the following:
1. Reseat ink cartridge
2. Replace ink cartridge with a specified ink cartridge for your printer.
3. If above steps wont resolved that issue, please call your printer manufacture and ask for service referral or process warranty options.
Tirzo
Oct 21, 2007 | Epson Stylus CX6000 All-In-One InkJet...
HP LaserJet 3050 All-In-One Printer Logo
517 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
