Question about Olympus D-535 Zoom / C370 Zoom Digital Camera
Settings affected
What settings are affected when I use the reset feature on the arrow pad?
    Master:
  • 852 Answers
The functions available from the arrow pad, which are Self-Timer (arrow left key), Exposure Compensation for adjusting brightness (arrow up key), Macro and Super Macro Modes for close up photos (arrow right key) will all be reset using the RESET arrow pad button. Also, the quality/resolution will be set back to the default of HQ, but settings such as the language, the date and time, sleep time setting and video out to either NTSC or PAL are settings which are not changed by using the reset button. These settings need to be manually selected through the menus in order to reset or change them.
Posted on Aug 31, 2005
SOURCE:
How do I complete a factory reset
Depends on the model of phone but this is for the Android based Motorola's
How do I reset my phone to factory settings?
Factory Data Reset is a tool used to remove everything that was imported, added or installed on the device.
WARNING: When using this feature; everything is deleted. Nothing stored on the MicroSD will be affected.
Important Note: Your contact and email information is automatically backed up to the Gmail server. Your information will be restored when you login with your user name and a password.
To Perform a Reset
  1. Open the Applications Tray. (arrow pointing up located in the middle at the bottom of the display screen)
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset
  5. Touch Reset Phone
  6. Touch Erase Everything
Note: You cannot reset/clear your phone remotely if it is lost or stolen.
To Manually Reset
If there are significant problems with your device or you are not able to follow the steps above please use the following process to manually reset the phone:
  1. Turn off phone
  2. Press Power key + "x" (on the hardware keyboard) to power on the phone and bring up the recovery screen.
  3. Press Volume Up + Volume down key for 10 seconds then press and release the volume down key..
  4. Using the volume keys scroll to Wipe data/factory reset
  5. Press the center of 5-way navigation pad
  6. Using the Volume keys, select Yes -- delete all user data
  7. Press the center of 5-way navigation pad
  8. Using the Volume keys select Reboot system now
  9. Press the center of 5-way navigation pad
Aug 05, 2014 | Cell Phones
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
My Maytag oven was shut off when a breaker was tripped. We turned everything back on however the clock says " 5ab" and none of the buttons work to reset the clock. Without this function, we can't...
That is the sabbath feature, to get it or defeat it:
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Thanks for using Fixya, let me know.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 06, 2011 | Maytag Ovens
Unlocked Samsung Behold can't make or receive calls
Factory Data Reset is a tool used to remove everything that was imported, added or installed on the device. Keep in mind, when using this feature; everything is deleted. Nothing stored on the MicroSD will be affected, but applications will be deleted. Your Social network and contacnt information is automatically backed up to the MOTOBLUR server and will be restored when you login with your user name and a password.
  1. Factory Data Reset
  • From the screen of your phone, open the Applications Tray. (arrow pointing up located in the middle at the bottom of the display screen)
  • Tap Settings.
  • Scroll down and tap SD and Card Storage.
  • Scroll down and tap Factory Data Reset.
  • Tap Reset Phone.
May 10, 2010 | Cell Phones
Touch pad
If you have the drivers for the touchpad installed then you should be able to run your finger up or down the right hand side of the touch pad and have it scroll the page you are one.
If it doesn't work then you may need to either reinstall the drivers or find the program that handles the touch pad settings (usually found in program files) and turn the scrolling feature back on.
Hope that helps :)
Mar 13, 2009 | HP Compaq Presario 2200 Notebook
Flash dont work on my fe 230
Have you tried to reset the camera to the factory default settings? There may be a setting that has the flash disabled. To reset the camera: have the camera in shooting mode - press Menu - left arrow to reset and press Ok. You will see Reset Yes or No. Highlight Yes and press Ok. This will reset the camera to factory settings. It will not affect any images that have already been taken. See if the flash is able to fire now.
Jan 12, 2009 | Olympus FE-230 Digital Camera
How to use the Zoom
I assume you mean when pressing the W or T buttons the zoom feature does not work. Try to reset the camera to the factory default settings and this should enable the zoom feature to work again. To do this go to Ok button and then to Mode Menu - then to Setup tab and then right arrow to Reset. hit the right arrow and you will see Reset Yes or No. Highlight Yes and press Ok. Camera should be in factory settings and zoom option will function.
Nov 13, 2008 | Olympus Stylus 600 Digital Camera
Settings affected
The functions available from the arrow pad, which are Self-Timer (arrow left key), Exposure Compensation for adjusting brightness (arrow up key), Macro and Super Macro Modes for close up photos (arrow right key) will all be reset using the RESET arrow pad button. Also, the quality/resolution will be set back to the default of HQ, but settings such as the language, the date and time, sleep time settings are not changed by using the reset button. These settings need to be manually selected through the menus in order to reset or change them.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Settings affected
The functions accessed from the arrow pad—Self-Timer (arrow left key), Exposure Compensation for adjusting brightness (up arrow key), Macro and Super Macro Modes for close-up photos (right arrow key)—will all be reset using the RESET arrow pad button. Also, the quality/resolution will be set back to the default of HQ. Settings such as language, date and time, and sleep time settings are not changed by using the reset button. These settings need to be manually selected through the menus in order to reset or change them.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Settings affected
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Olympus D-535 Zoom / C370 Zoom Digital Camera Logo
107 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
