KitchenAid K45SS Classic Stand Mixer Logo
Posted on Jul 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Speeds don't increase after 6 - KitchenAid K45SS Classic Stand Mixer
Anonymous
Level 2:
Novelist:
  • Expert 153 Answers
  • Posted on Jul 04, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
153
Questions
0
Helped
71198
Points
327
The K45SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
  • 1 more comment
  • anonymous
    anonymous Dec 24, 2014
    I followed this tutorial and BROKE my mixer.
  • anonymous
    https://www.youtube.com/watch?v=pUo_ZU5x... This gives the opposite directions (loosen the screws first and *then* tighten them slowly) Wish I had tired that tutorial first.
  • anonymous
    tried*
Mixer works fine with speeds up to 6, but changing to 8-10, speed stays the same.
Sometimes can be caused by running too fast on the lower speeds. Should be 13 to 15 revolutions in 15 seconds on speed 1 then a slight increase only on speed 2.
Mixer doesn't work on all speeds
First the K45SS does not have a hall effect sensor. the pro series the epicurean seines and the pro series 5 use them, The K45ss system uses a phase control board a speed control plate and a governor for speed control. the governor rarely goes out the phase control board is a likely culprit but the system would work only in high gear if it was bad. I agree with the guest above in that it sounds like the retaining nuts on the adjusting screws of the speed control board have worked themselves loose and the adjustment screws themselves have vibrated out of proper position.
DORMEYER stand mixer maintenance
Sadly, the service directions, while excellent, are for a Sunbeam Mixmaster Model 12...uselful for a Dormeyer only in the most general of terms.
Dec 12, 2011 • Food Mixers
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
First, you may want to adjust the mixer's speeds:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
2helpful
Only works speeds 6-8. Turns off when moving knob to lower speeds. Tightening two screws in the back of the mixer above the power cord changed the working range from 4-6. Any ideas?
You need to adjust the mixer speeds:
All three (2 top left and right, and 1 bottom) must be adjusted.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
I have a Kitchen Aid k45ss that was dropped a few years ago. I works fine but the speed switch doesn't want to stay in the off position so we have to unplug it. I opened the unit and the switch...
When you said "the speed switch doesn't want to stay in the off position", you meant to
say "the speed switch in the OFF position does not turn OFF the mixer", or "the speed
switch physically cannot be moved to the OFF position"?
In any case, try to adjust the mixer speeds.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
4helpful
Kitchenaid speed controller (don,t work
Obtain a copy of the KSM150PS Repair Part List from Kitchenaid.com.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
1helpful
I was grinding some meat and my mixer got very hot. I let it cool down and now it only operates at one speed.
I am not sure what has happened to your mixer but, select
different speeds from Stir to 10. If it runs OK, then there is
nothing to worry about, otherwise do the following to re-adjust the mixer's speeds:
Get a copy of the Repair Part List of your model from Kitchenaid.com
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
1helpful
My wife's Kitchen Aid Artisan 325W mixer has no high end speed. I tried a new set of brushes with no change. Then starting on speed 1 to 2 and from 2 to 4 you get a nice speed increase the speed the...
You need to adjust the mixer speeds. Obtain a copy of the KSM150 Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
1helpful
I could not regulate the speed as usual. Hubby removed the phase control board and a new one was purchased #9706595. It arrived and was installed and now the mixer won't even turn on. HELP please.
The K5SS is very similar to the 5-QT Artisan KSM150.
You need to adjust the mixer speeds. Obtain a copy of the K5SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
