Question about Zanussi FJS1225W Front Load Washer
Washer dryer zwd 1480 zwd 1680 when i put a wash on after a couple of minutes it shoots down to 3 minutes and finishes. any ideas????
I have exactly the same problem, I am doing some testing with mine at the moment and I believe it to be one of the two thermostats in the heating chamber.
If you was to remove the top cover you'll find a long silver cilinder running through the middle of the unit. Looking from the front there are two modules on the left side (thermostats) with 2 wires connected to each towards the back of the dryer. These measure the temperature inside the heating chamber, on removing them the heat stays on, you have probably noticed the dryer is not even getting hot so the moisture sensor won't pick up any moisture in the air so the dryer trying to be cleaver with think the clothes inside are dry and finishes the cycle early.
I wouldn't reccomend removing these thermostats as it will probably overheat and cause a fire risk, however they should only cost a couple of ££ to replace.
Now I've just got to try and source the parts!!
Posted on Sep 13, 2008
How does the soft fabric tray empty?
washer will shoot water into tray during rinse cycle only therefore emptying tray into washer
Aug 01, 2014 | Zanussi Washing Machines
My Zanussi zwd 1270s washer dryer keeps tripping the MCB and i have no idea why, any help?
Washers take alot of power to run. In the instlation manuel they say to have a dedicated electric line .
i had a problem with mine i had a sump pump and the dryer and washer on the same line and would trip my breakers.
You can run it off another line or extention cord as long as its rated for the needed amps.
Sep 24, 2011 | Zanussi Washing Machines
I have a zanussi washer dryer ZWD 14270w and the dryer is taking hours and hours to dry anything..help!
Not sure how full the drum is when you are using the dryer, but I have this appliance and it works best if the drum is half full. If the drum is full, things don't dry properly because the air can't circulate.
If that doesn't work I'm out of ideas!
Oct 24, 2010 | Zanussi WDA1055W Front Load Washer / Dryer
My Zanussi ZWD 1470W won't fill up with water. I
Story could be lengthly so in brief, check to see if drain pump is not blocked and if door latch is functioning correctly.(use a multimeter if you can). If it all measures out as good, then your control is faulty. Does the water fill up to the correct level when you start the cycle? Does the motor hum when trying to run. If so check the capacitor.
May 20, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
I am getting a Code E21 on Zanussi Washer Dryer ZWD 1271W. This is on the Dryer cycle everything else seems to work. Thanks
E21 Problems with water drain in wash phase
Check the drain hose and pipe for blockages.Replace the component if necessary.Good luck with the machine.Please do post comments and results.
Apr 15, 2009 | Washing Machines
Door locked
Press 'end of cycle' button for over 3 seconds, & wait for a couple of minutes then try the door. Do not force door.
Mar 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Zanussi FJS1225W Front Load Washer Logo
206 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
