Question about Sony Handycam DCR-TRV350 Digital Camcorder
URGENT NEED HELP WITH C:31:23 CODE ON DISPLAY SCREEN
THERE IS A C:31:23 CODE FLASHING ON THE SCREEN AND WHAT LOOKS LIKE A EJECT SIGN FLASHING ON SCREEN I get the same code and icon flashing. as others have mentioned. My first instinct was to think that the humidity down here in the south was causing it (Aug 22). My case will close and open. I can insert and remove the tape. It will not record. I've rebooted several times. How do I resolve this error code?
Thanks
Dave in Mississippi
  • 10,594 Answers
Error code shows problem in Take-up Reel section. Its mechanical / electronics problem, not generating reel puls, so system control shut down cassette movement in playback / recording. You need to open camera in detail to repair this problem.
Hope this info will help you.
Posted on Aug 24, 2008
  • Sony Master
  • 6,487 Answers
Try this:
Turn off the camcorder.
Remove the battery or disconnect the AC power adapter for 60 seconds.
Insert the battery or reconnect the AC adapter.
Turn on the camcorder.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Hope that helps........
  • Sony Master
  • 19,396 Answers
Try first removing the battery and see if this clears the error.
  • Ginko
    Ginko Aug 24, 2008
    Here is complete procedure you should follow:
    do the following:
    1. Turn off the camcorder.
    2. Remove the battery or disconnect the AC power adapter for 60 seconds.
    3. Insert the battery or reconnect the AC adapter.
    4. Turn on the camcorder.
    5. If the error message appears, service may be required.
When the cam is put on recordning mode a error on the screen shows the following- eject sign followed by ...D , On top on screen its written EJECT LP
The error display shows that the camcorder has some mechanical fault.Follow the instructions below.
1. Eject the Tape
2. Set to OFF
3. Detach the battery
4. Reattach the battery
5. Power ON as usual
Simple faults will be recovered when performing the above procedure.Good Luck
Jun 04, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
Greetings,
FATAL ERROR CODE : unit is unable to perform requested operation
No reset or fix for that problem.
New camcorder or repair - get a quote for repair and compare price for a new one.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 20, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
What does the engine sign start flashing on a 1994 honda accord exclusive means?
must have someone code read vehiclescomputer to find out.. some things more urgent as compared to others....
Mar 19, 2011 | 1996 Honda Accord
SONY DCR TRV350 C31:23 and C31:22 flashing code
Hi Jeany,
Please see the detail below for the said error codes C31:23 & C31:22
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Jun 15, 2009 | Sony Handycam DCR-TRV240E Digital...
Samgung SC-D353 camcorder 'EJECT' problem
sc-d353 got wet slightly the camera part is working but good tapes display eject sign and in the middle of the screen displays the eject symbol and ...r please help
Jun 02, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Help please urgent
It may have been the outer casing to the lamp and the lamp may still be bad - that's normally what the flashing power button indicates. Do you have a specific model number for the tv?
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
the reel sensor is the problem of your camera...in my job as a technician i always encounter that..it is a poor connection of the sensor to the mainboard..try to clean the contact using only a pencil eraser and put it back to the socket....
Jun 16, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Message icons
flashing envelope means your msg in SIM ARCHIVE is full.
wap sign means you postpone the dowloading of wap session sent toyou.
Feb 13, 2008 | Sony Ericsson T610
Sony handycam CCD-TRV43 troubleshooting
Some part in the cam is broken and i want to repair it. where should i go in Navi mumbai India?
Aug 08, 2006 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam DCR-TRV350 Digital Camcorder Logo
269 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
