Question about Gateway FPD2275W LCD Monitor
GATEWAY FLAT SCREEN
15IN FLATSCREEN #0026 406 757
MONITOR LIGHT COMES ON, BUT NO ACTIVITY
FUSE? HOW DO I REMOVE & CHECK?
THANKYOU
SINCERELY
TERESA BROWER
TBREESER@YAHOO.COM
    Problem Solver:
  • 7 Answers
Most likely one or two faulty capacitors in the power supply.
If you open the unit, they are cylinders with flat tops, if they are bulged at the top it means they are faulty.
Usually the faulty ones are rated 16 volts, 1000 uF.
Its safe to replace with 25 volt 1000uF (microfarad) ones.
Posted on Aug 26, 2008
I have a compaq presario computer using a compaq monitor. I have a Gateway HX2000 LCD flat screen monitor (year 2009) that I want to us instead of my compaq monitor. I have disconnected the compaq monitor...
I'm guessing the different monitors are different sizes? The only thing a driver for a monitor will do will tell the computer the max resolution that the monitor will be able to go up to. However most 90% of monitors can use the built in windows driver without issues. Your best bet is going to be to change the resolution on the monitor. To do this you can either hook up the old monitor, lower the resolution, and then plug in the other monitor. Or you can boot the computer into VGA low resolution mode by pressing F8 as the computer starts up and selecting that option. From there you can lower the resolution, and then put it at something more desirable with the new monitor.
The other possibility being your Gateway monitor is actually malfunctioning and you just happened to hook up a bad monitor.
Mar 27, 2011 | Computers & Internet
My 19" flatscreen monitor flashes on a blank screen and the power button light flashes on and off blue, no picture.
Problem in Your monitor VGA cable no horizental or Vertical signal.So it is not active standby mode.Check signal or VGA cable on not adjust properly CPU.or any other device.May be VGA cable was broken.Replace it.If you are not replace the part so you can get help any service technician.
Dec 27, 2009 | Soyo 19" LCD Flat Panel Monitor
Hello there is power but no back light.....Don't know if it is the back light or main power supply...Can you help? Thank you
Hello there is power but no back light.....Don't know if it is the back light or main power supply on my gateway flatscreen computer monitorCan you help?
Nov 21, 2009 | HP f1905 19" Flat Panel LCD Monitor
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
FPD1530 15in flat screen Config. issue
The native resolution of the monitor is 1024 x 768, so set your computer resolution to that value. If necessary, restart the computer with the monitor powered on.
Here's a link to the User manual:
Gateway FPD1530 User Manual Fpd 1730 Specifications
Nov 19, 2017 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway fpd1530 15in flat
There are more than one inverter circuit for this model. One is prone to have poor solder connections in the transistors Q8 & Q10.
Another can be repaired by replacing 2 1uF electrolytic capacitors near the center edge of the board between the lamp sockets.
Monitor Mike
Nov 15, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway flatscreen monitor
There is a problem with the power supply cable to this monitor. You need to have a new one put on. An easy way to test this is to get it to a shop so they can test the cable.
Jun 11, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
How to my flat screen monitor
This is a duplicate post, click the following link to see the active post: http://www.fixya.com/support/t136495-fix_flat_screen_monitor
Mar 06, 2007 | Dell E153FP 15" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
65 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
