This sounds like an Alarm issue. If you had an alarm added to the vehicle after it was purchased you need to deactivate that by removing the power wire or fuse in the power wire. if that vehicle has the alarm built into the PCM, the vehicle computer, it may just need to be flashed. If neither of those turn out to be the problem the next place to look is the light switch itself or if you have added a device that was wired into the fuse panel for power double check the fuse panel for a lose wire making contact on occasion.
