Question about Car Audio & Video
I have just installed a new Sony car hi-fi in my old VW camper van. It works but the sound is distorted. I have kept the original old speakers which are 50watt Blaupunkt, which is the wattage for the Sony. Do I need new speakers or could I have wired up the Sony incorrectly? Andy
  • 3 Answers
I think you need new speakers
Posted on Aug 25, 2008
Recommendations for replacement 6 inch speakers with the Jensen AWM 968? They are for my rv, and are the only speakers in it. Thanks in advance for any help!
In-car entertainment systems, especially the types chosen for camper vans, etc., are often capable of quite high power outputs and usually need speakers capable of being driven at those high power outputs without damage.
The trouble is, such speakers usually don't sound so good at the very low volume settings needed for evening and late night use in a campsite environment to avoid annoyance to neighbours.
It is a big problem choosing speakers that sound good at low volume and yet can withstand the higher volume needed to overcome the wind and road noise of driving. There have been many technological advances in speaker design and a hi-fi specialist will undoubtedly be able to make suitable recommendations that are resistant to damp conditions, long-lasting and with cones free enough for good reproduction at ultra low volumes but robust enough to withstand high power outputs and such drive units are likely to be fairly expensive.
For myself I would choose to use a dual speaker system with a multi-speaker system comprising several low-powered speakers strategically placed for low volume use and a fairly standard high-powered system for normal use and a selector switch.
Aug 01, 2016 | Jensen Car Audio & Video
The bass in my Sony 3-way 6X9 speakers wont work
if these speakers are several years old, chances are that the left one is just blown. could be a loose wire, but if not, it would be cheaper to get new speakers than to get that one fixed
Apr 05, 2012 | Sony 3-WAY 6X9 SPEAKERS Car Speaker
Subwoofer suddenly making buzzing sound but is not hooked up to anything,fuses arent blown and its been in the same spot for a few years and never had a problem.happened suddenly.moved it to another spot...
hi pls make sure that there isn't any other magnetic or electromagnetic device near the speakers because due to induction ur speakers magnetic field gets distorted which makes that buzzing sound irrespective of no fault wiring may be this may help u or see that the wiring near the woofers speaker magnet is attached strongly so that it doesn't distorts any more was this helpful if yes pls vote
with warm regards - bonefirediv
Mar 25, 2011 | Car Audio & Video
Distortion
The wattage rating, I take it, for the speakers is more than 45 watts right? Check to make sure that you connected the right wires to each speaker,front right + wire to front right speaker, not front right +, to front left + and make sure that the -'s are connected to the -'s, and the +'s are connected to the +'s.
Mar 29, 2010 | Alpine SXE-1325S Coaxial Car Speaker
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Just bought a new car. i removed old stereo and put in my kenwood kdc-w808. whenever there is base in a song it distorts i have to turn my base rite down to get rid of it. worked perfectly well in my old...
your speakers probably cant handle the bass.,also they are probably full range speakers ,so hwen the base hits at the same time a voice is singing the woofer is vibrating to produce the basss,there fore distorting the highs and mids {or voice}.You need to add a seperate sub woofer.And puyt capicitossr on the full ranfge speakers to limit the bass..Rating please. :}
Jun 16, 2008 | Kenwood Car Audio & Video
Distortion from an unboxed 12''
hook the leads up to a wire connected to a 120v wall outlet and the problem wont bother you any more.
Jun 01, 2008 | Sony 12" Single-Voice-Coil 4-Ohm Subwoofer
Brand New Speakers Distorted and not right...
Are you still using the same head unit? You could try to run a short set of new wire to one of the speakers directly from the unit. Had you previously used these speakers in another vehicle...what I'm getting at is that you need to isolate the problem. If the speakers test fine in another vehicle, I would think there is something wrong with the existing head unit
Dec 31, 2007 | Pioneer TS-A1057 Coaxial Car Speaker
Installation a new speaker in stock sound system
One thing you should know when you install the new speaker it is going to pull most of the power away frrom the factory speaker. In order to get the true sound of the speaker, remove the factory one..I know that the door panel might give you trouble, but it will be worth the trouble..If you tell me what kind of car you are working with, I can help you remove the panel easy.
Dec 21, 2007 | Dynaudio MW 160 Car Mid-Range
Car Audio & Video Logo
104 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
