Question about Jl Audio 1000/1 Car Audio Amplifier
Jl audio 1000/1 amp
Low ohms light came on !how do i get the amp to reset
  • joe_getmet Dec 05, 2008
    Hi I disconnected the whole amp for more than 15mins but my low oms light keep coming on constantly still on my 500/5 how do i reset it
  • Anonymous Feb 17, 2009
    I have the same problem and I have tried to reset it by taking it all apart but that didn't work.
  • 113 Answers
Disconnect power and remote for 15min
Posted on Sep 08, 2008
JL Audio 1000/1 v2 distortion problem
Make sure all your connections are tight , really tight . Check ground , make sure it's to clean shiney metal. Three subs are going to have a low ohm load if paralleled . These amps are not 1 ohm stable ,if below 1.5 ohm's you will have problems. They need to be series paralleled to raise the ohm load. These amps put out the same power from 4 to 1.5 ohms.
Mar 14, 2012 | Jl Audio Car Audio & Video
I looked up the correct way to wire my JL 13.5W7 1.5. Therefore it said to wire it in parrallel. I understand this will put it at .75 ohm. As I start to turn it up it sounds great, very loud but once the...
1000/1v2 Class D Monoblock Subwoofer Amplifier Specifications:
Rated Power:
1000 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
THD at Rated Power:
<0.05% @ 4 ohm
S/N Ratio:
>95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response:
5 Hz - 250 Hz (+0, -1dB)
Damping Factor:
>500 @ 4 ohm / 50 Hz
According to the chart your amp is only stable down to 1.5 Ohms, so running at .75 Ohms the noise you are hearing is the amp clipping (running more power than it can handle at low ohms)
I would suggest wiring it in series, or you could adjust the gain on the amp until the popping goes away.
Hope this helps.
Nov 10, 2010 | Jl Audio 13W7 Car Subwoofer
I have a green light on and the low ohms light on whats the problem?
no problem i see. Should be the power light, and the lower the ohms the better it is.
May 11, 2010 | Jl Audio 1000/1V2 Car Amp
When i turn the volume up my jl 1000/1 amp turns off then turns back on when the volume is low what can i do to fix this?
2 things, either your pushing too much power into the imputs (if using high inputs) and clipping the signal, or your running the ohms too low (lower then the amp can handle safely) by running multiple speakers of too low an ohm each. For example if your amp is 4 ohm stable and your running 2 4 ohm speakers in parallel that makes 2ohms and the amp can't handle a load that low. You can consult your manual and it will give you illistrations of wiring and ohm loads
Oct 26, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Low ohm light stays on my jl 1000/1
you have your amp wired at too low of an ohm load for the amplifier. This is why it is doing this. Jl amps are awesome and pretty much make everything idiot proof. Not calling you an idiot but go online and search for that model on then look on either the box your subwoofers came in or on the back of your subwoofers. Find out which ohm load they are and how many voice coils. Next go to and find the subwoofer wiring diagrams close to the top of the page. Then enter in your information on your sub's impedence and how many you have then it will give you the wiring options that you have and it will probly tell you you are wired at like a .5 ohm load. And let me guess you turn it up too long or too loud and your amp gets hot and it goes into protection.
Jun 09, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Will a JL audio 1000/1 amp run a orion HCCA 15
Hello evopower,
The JL 1000/1 will power the Orion HCCA OK.
It is stable only to 1.5 ohms so your best choice would be the 15.4 with dual 4ohm voice coils. In parallel, this would offer a 2ohm impedance. The 15.2 could only be wired for either a 1ohm load (too low) or a 4ohm load (less power).
Hope this helps.
May 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Low ohm light comes on and loud humming sound comes from amp and sub have a j1000 and 13 w7
nice set up, how many speakers are you running? you have something wired up weird causing the ohm level to drop to low. we can fix this let me know and ill help you.
Mar 07, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio amp 1000/1 fix
Dec 22, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Low ohms light ! ! ! !
How are the speaker wired and what is the ihms for the speakers?
Dec 06, 2007 | Jl Audio 1000/1 Car Audio Amplifier
JL Audio 1000/1
Check the resistance between the positive and negative terminals of the speakers. There should be atleast 1 ohm of reistance depending on your set up... if there is very little there is a short in your wiring. If not remove the wires from the amp and now check the resistance between the termanls on the amp...there should be no condinuity...if there is your amp has short circited out.
Feb 18, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 1000/1 Car Audio Amplifier Logo
483 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
