Question about Olympus Camedia D-520 Zoom Digital Camera
File sizes
What are the file sizes for the images in various record modes on the D-520 Zoom camera?
    Master:
  • 852 Answers
Record Mode Recording Size (Resolution) Max. File Sizes SHQ 1600 x 1200 Approx. 1.3MB HQ 1600 x 1200 Approx. 418KB SQ1 1024 x 768 Approx. 213KB SQ2 640 x 480 Approx. 140KB
Posted on Aug 31, 2005
I own a Nikon Coolpix L18, it is currently set to 8 MP. I want to minimize the file size, where can I find this in the camaera settings?
You can change the megapixel under the image mode. That would make the file size smaller. Otherwise, you can change the file size once you've transferred the pictures to the computer. There are various downloads available to do that.
Jun 16, 2008 | Nikon Cameras
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Features of each record mode
The details for each record mode are as follows: RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth. TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer. SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored. HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ. 3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode. SQ1/SQ2: SQ1 is used for resolutions above 1600 x1200 and SQ2 is used for resolutions below 1600 x1200. For both, you can choose high compression to reduce noise or normal compression to save more images.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Features of each record mode...
The details for each record mode are as follows: RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth. TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer. SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored. HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ. 3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode. SQ1: SQ1 uses the highest compression for resolutions greater than 1600 x 1200. You can choose high compression to reduce noise or normal compression to save more images. SQ2: SQ2 uses the highest compression for resolutions less than 1600 x 1200. You can choose high compression to reduce noise or normal compression to save more images.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Compression rates
Record Mode Recording Size (Resolution) Compression SHQ 1600 x 1200 Approx. 1/2.8 HQ 1600 x 1200 Approx. 1/8 SQ1 1024 x 768 Approx. 1/6 SQ2 640 x 480 Approx. 1/4
Aug 31, 2005 | Olympus Camedia D-520 Zoom Digital Camera
How do I make an image file smaller so I can send it by e-mail?
To make an image file smaller for e-mail transmission, change the image file size in "Exif Viewer" or "FinePixViewer". Changing the size of an image file 1. Start up the Viewer and select the folder containing the image you wish to send. 2. Double-click the thumbnail for the image file you want to resize to open the image in its own full-size window. 3. Select "Image size" in the "Image" menu. 4. Set "%" as the "Unit" used for file size display. Then enter a value lower than 100 as the "Width" or "Height" and click the [OK] button. 5. Select "Save as" in the "File" menu to save the image. (You can also reduce the image file size by lowering the quality in "Save as type".)
Aug 30, 2005 | Fuji FinePix 2400 Zoom Digital Camera
What is the procedure for sending pictures over the Internet in FinePixViewer?
Aug 30, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Aug 29, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Olympus Camedia D-520 Zoom Digital Camera Logo
60 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
