Hi i need your help please
Hi i've been reading and i noticed you know about this stuff rear projection tv's i wanted to ask a question i have a 52 in philips rear projection tv and i was adjusting the color through the back i opend her up and suddenly all the three lamps whent off i just get sound if i turn it back on the lamps go on for about 5 sec then they shut off no light just sound what do you think it might be and is it costly to repair becaus it was working fine before it was just too blue and as i was moving the color it shut off thank you for you help
  • sobayjay Aug 25, 2008
    thank vey much i thaught it was done but yeah i turned them down and it works fine now it's still has blue shadow arround the black do you know how i can fix that but thank u much for the other problem i had
    thank you for your i really appreciate it
  • 8,617 Answers
When you adjsuted for the blue you were actually adjusting the voltages to the CRTs (lamps) which in turn shut them down. You will need to turn each one of the dials up agin untill your tubes stay lit, then the coolant in the green and blue CRTs will need to be changed as the green evidently is contaminated thereby making the blue dominant. But when you turn down the G2 controls your actually turning down the High voltage to the picture tubes thats why they dropped out on you.
Posted on Aug 25, 2008
  • Sonny Berry
    Sonny Berry Aug 25, 2008
    change the coolant in the CRTs thats what causes the halp effect and makes the colors abnormal. You can get a Coolant change kit at the following link which contains all the coolant and the complete step by step instructions on CD with pictures. Its listed under their repair kit category. Here is the link.
    http://servicemanuals.vstore.ca/
My RCA D52W19 HDTV Ready TV will not turn on. The power led comes on three times after pressing the button on the tv itself or attempting to power on with the remote. The condition has been getting worse...
Hi Aaron,
I just want to ask you something before I give the solution, does the unit gone to start-up problem (needs warm-up before it finally turn on, needs to pressed the power button key several times, needs to unplug from the outlet and plug it back in)before, you have said that you've encountered it last few months?
Jdvillanueva
Sep 29, 2011 | RCA D52W19 52" Rear Projection Television
I have the RCA HDTV rear projection 52" and you use either the remote or the on/off button on the tv and it turns green you hear the static and have sound but no picture and then it powers back off. ...
I've encountered many of these televisions from RCA with poor solder connections, on the deflection supply module. This is furthest left module when facing the rear of tv. Has a red wire coming from a plastic enclosed transformer. Check beneath the transformer for cracked or open solder connections. Good luck and be carefull to press back the large plastic retaining tabs on outside of and near center front and rear to release the module. If you have a magnifying glass you may see a noticeable ring around some connections. Use a pencil iron please! Not too much heat.
Jul 11, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Have a 52 inch rca d52w20 rear projection tv, the tv was on then it just turned off..attempted to turn it back on and heard a sqeaking noise and tv will not turn back on.. please help..
replace the flyback, very easy repair. You need flyback 259296 you can getone at the following link with free step by step instructions with pictures. heres the link read their reviews.
Jan 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need solution
Appreciate the direct "Ask Me".
Your concern with an RCA D52W26 is when you attempt to turn it on, it powers up as indicated by the LED lights but they then power OFF a few seconds later? or it powers on then you get to see bright line(s) left to right, then the TV powers OFF? or it powers on but only bklinking LED lights? If yes on the last any sequence to the flashing/blinking?
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52w20bxy1- 52" RCA Rear Projection
3 blinks is definately the flyback 259296 and quite possibly the HOT which is a 2SC5588 you can get replacement flyback and HOT at the following link and they will give free tech support to help if you need it. Heres the link.
Aug 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20 52 in rear
Hello, I would take it to a TV repair place, they will charge around $50 and let you know what the problem is with it. this is your cheapest way out, it you want to keep it. If you chose to take it please give me a fixya rateing. Thanks, Farren
Dec 14, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
