Question about Kitchen Ranges
I have an electric Maytag,digital display, single oven, self-cleaning stove. Top burners work (Ceran Schott was imprinted on top surface, upper left corner). Oven will not heat, error code F1 appears along with beeping noise when attempts are made to turn oven on. Home was just purchased. No manual was available. Model # is not legible, only serial #8114P695-60.
  • 639 Answers
Hi Mearill,
Happy to help you!
At this site you may download a manual !
http://www.maytag.com/support/manuals_literature.jsp
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
Schott Ceran. Why doesn't oven work?
Might try heating element in stove
Oct 03, 2015 | KitchenAid Kitchen Ranges
Maytag schott ceran front eye wont get hot
I navigated the SCHOTT website to find a solution and was able to find out how to properly clean my SCHOTT stove top. I would check the Ceran FAQ list to see if your question is answered before anything else.
Nov 19, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
Copper Bottom pots left on burner when dry
use a metal polish like "brasso" it is a mild abrasive
Feb 25, 2010 | Maytag MER5775Q Electric Kitchen Range
I have a Schott Ceran cook top that is marred with black stains all over the burners. The stove works, but looks awful. How much would it cost to replace top? The marks seem to be appearing from the bottom...
Use oven cleaner. Spray it and let it sit on a couple of hours. Scrape with a razor blade. It worked for me after trying everything recommened by the manufacture.
Feb 20, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Maytag gemini schott ceran stove top
Sugar spills on a hot surface will 'pit' the glass surface. There is no way to repair. The damage caused to the surface is only cosmetic and will not affect the performance or operation.
Jun 16, 2008 | Cooktops
MAYTAG Model ME5770AAW Ceran Top Stove
the lights come on but the burners will not heat up what would be the issue
May 31, 2008 | Maytag MER5775Q Electric Kitchen Range
Maytag ceran top stove
MY CERAN SURFACE TOP HAS CRACKED ON MAYTAG MODEL BCRE955. CAN IT BE REPLACED AND ARE THE TOPS AVAILABLE?
Feb 10, 2008 | Maytag MER5775Q Electric Kitchen Range
Problem w/burners & lights after self clean
You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows.
First, unplug the range.
LIFT–UP PORCELAIN COOKTOP
To lift:  When cool, grasp the cooktop front
edge.  Gently lift up until the two support rods
snap into place.
To lower:  Hold the cooktop front edge and
carefully push back on each support rod to
release.  Then lower the top into place.
COIL ELEMENTS
➢When an element is on, it will cycle on
and off to maintain the heat setting.
➢Coil elements are self-cleaning. Do not
immerse in water.
To remove:  When cool, raise element.  Carefully pull out and away from receptacle.
Check them for damage. They do wear out.
To replace:  Insert element terminals into receptacle.  Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl.
COIL ELEMENT SURFACE
➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(800)688-9900 U.S.
(800)688-2002 Canada
Dec 03, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Whirlpool Oven, Ceran stove top
I want to say that since I posted my original problem with black spots appearing on the Schott Ceran top, I took pictures of the top and attached them to a complaint sent to Maytag. Approximately 3 days later, a Maytag representative phoned and offered a brand new top-basically stating that there is a fault with the tops. They would not pay for the labor to replace the top. My husband downloaded the instructions from Maytag website and installed it himself. These spots actually appear from within the surface and are not the result of a boil over, etc. The spots on my burner grew to the width of the burner. If you search the internet, you will see many others with the same problem with the Schott Ceran tops. I will never buy another!
Nov 20, 2007 | Cooktops
Schott Ceran cooktop on Maytag range
try clr from a local supermarket.it comes in a green plastic bottle.wipe the burner generously but not soaking wet with it and turn the burner on the lowest setting.then use a metal scouring pad and LIGHTLY scour the burner.
Aug 11, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
648 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
