Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Straight line turned the tv on heard a pop and a straight line shows on the picture tube.
  • katsnide Jan 21, 2009
    My tv did the exact same thing this week. I am having trouble finding the part number for a vertical output transistor. A lot of transistors are listed for this tv but don't know which one to order. Any help?
    Problem Solver:
  • 15 Answers
You need to replace the vertical output transistor. part are available online at www.digikey.com
Posted on Oct 17, 2008
I think my picture tube just blew up It will not power up
since projection tvs have 3 tubes, it sounds more like a fuse, or power supply.
May 07, 2012 | Panasonic Televison & Video
TV turned on, heard loud pop. Now screen is very dark.
It sounds like the actual tube / lamp inside the unit has exploded. You will need to either get it repaired at a local TV repair shop or replace the TV. Unfortunately with that unit it is probably cheaper to just replace it.
Jul 27, 2010 | Akai PDP4225M 42 in. Plasma Television
Replace bulb
There is a small access door on the rear panel of the set. Open that door and you will see the lamp cage it pulls straight out.
Jul 08, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
53" sony projection -picture washed out w/ green horizontal lines
It sounds like your Green CRT ( picture tube ) is shorted. That's the one in the middle. Sony had issues with there tubes in those years. Sorry for the bad news. Even if you could locate the tube, it will be a matter of time before the Red or Blue does the same.
May 03, 2009 | Sony KP-53S65 53" Rear Projection...
LG plasma tv made loud popping noise
The plasma gas tubes may be damaged or the gas couldve leak out. remember plasma have to remain upright at all times even when transporting them, if they are not you should just set it up straight for about 3-4 hours before turning it on.
Apr 23, 2009 | LG 50PX5D 50 in. Plasma HDTV
White Lines and Bright Screen
I believe you have a shorted transistor on the crt board on the back of the picture tube which should be Q5104. Let me tell you my experience with these Zenith's The original problem is the picture tube shorting out and caused this problem. If you replace the transistor the same problem could arise again because of the tube and it could even knock out the main board power supply. I have seen this happen. And I have put in the transistor and no problem. You can get one at the Radio Shack by taking the bad one out and get them to cross reference it for you. All Zenith transistors have a prefix number (not on the transistor) which is 121- (with the dash!) and the number on the transistor The new one must go back in the way it came out! I recommend someone with electronic soldering and desoldering experience. Hope this helps
Dec 29, 2007 | Zenith SY2765S TV
Toshiba 32A41 TV -- color problem
Toshibas are notorious for developing shorts in the inernal guns of the picture tube. In your case the green gun is shorted to G1. The noise you heard was an internal arc between the elements. It is unfortunate however, the repair of this problem usually requires the picture tube to be replaced. Sometimes a savvy technician with sencore picture tube rejuvenator can remove the short. This however usually does not last. Scrivitron
Jun 16, 2007 | Toshiba 32A41 32" TV
POP and noothiing
yes it can still be fixed! the pop sound you've heard maybe came from a blown capacitor in the vertical deflection circuits. this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 10, 2007 | RCA E13309 13-Inch Diagonal XL-100 Color...
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
156 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
