Question about Canon PIXMA MP530 All-In-One InkJet Printer
Error 5100 for canon mp530
I have a Canon Pixma mp530 and the Copy and Alarm lights are flashing and reads Check Printer 5100. I have tried moving the print cartridges and turning it off, but the error will not clear. Any Suggestions??
  • ebond Aug 25, 2008
    We have been unable to send or receive faxes for quite sometime. The alarm was on and the printer read 'check printer'. I opened all components to see if there was a paper jam, closed up all components, unpluged the printer/fax machine for a few minutes, then plugged it back up only to receive the same reading 'check printer'. Afterwards, the printer went out and we received a replacement; we were able to connect the printer portion with no problem, but the fax machine is still not working. Can you help?
    Eliza Bond
  • 876 Answers
I would do all of the following and see if yo can clear this code. It is not on any Canon list of possible codes, so I have no idea what it means., but let's do this:
Turn off the printer and unplug it.
Remove the print cartridges. Look at them, are they leak free? Look into the cartridge holders. Are they clean?. Dried ink or blobs should be cleaned off with a little alcohol and a qtip.
Are the little wire holders bent or broken? Do they look exactly the same?
Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges.
Now turn it off again and unplug it. Open the paper jam door and gently push the paper roller forward until it clicks. At the same time, look for even the tiniest scrap of anything in there.
Close the paper jam door and plug your printer back in. Restart your computer.
If the problem is not solved. You may need to reinstall the printer. Do You have your original disc? Be sure to do a clean install. ( Turn off all running programs in the lower right corner including your virus control. Also go to Toolbar>tools>internet options>general>and delete all you cookies and temporary internet files.) Turn off and unplug your printer.
Reinstall the software. When it is finished if it has not told you to plug your print back in do so now. Restart your computer and turn your printer on.
I hope this helps. Good luck to you.
Posted on Aug 24, 2008
I have a Canon PIXMA MP530 printer and showing an Service Error 5C10. What is that error? It will not print and the Alarm light flashes.
disconnect it from power for 10 minutes and also check for jammed paper. That should do the trick
Rob
Ps. Thanks for ratings.
Mar 02, 2011 | Canon PIXMA MP530 All-In-One InkJet...
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp530
As best I can tell from the User's Guide (available here if you don't have it), page 146, 5100 is a Service Error indicating that the print head is blocked/can't move. Remove power from the machine, open the top and check carefully inside to see if there are any pieces of paper or other items which may be blocking the print head from moving back and forth.
If you still have the same error after reapplying power, the unit probably needs to be serviced. You can use this link to find an authorized service facility near you. Give them a call and see if they can give you an estimate for repair.
Semper Fi Devildog, and good luck.
Jun 03, 2008 | Canon PIXMA® MP530 All-In-One Printer
Canon mp530 getting error message 6a00
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
Jan 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon printer pixma ip6220D is showing error code 9000 alarm light flashing. What to do please?
Canon printer pixma ip6220D is showing error code 5100 and alarm light flashing. Help me how to repair it?
Dec 21, 2007 | Canon PIXMA iP6220D InkJet Photo Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
905 people viewed this question
Clive
Clive
old marine
old marine
