Question about HP DeskJet 1280 InkJet Printer
The printer print from word but not print from auotocad.
Dear sir
the printer print from word but not print from auotocad. I have w xp on my pc.
thank you for your help
  • 876 Answers
Here is a link that should help you:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2876900&linkID=9240617
If you have any further questions please feel free to ask.
I have one question? Has it ever printed Autocad? Have you done a compatibility test from START>All programs>Accessories>
Program compatibility Wizard. You may want to try this as well.
Thank you for using Fix Ya and the best of Luck to you!
Posted on Aug 24, 2008
Dear Sir I am using IBM PC Celeron, Operating system Windows XP Service Pack1. HP Printer D1560 Deskjet printer is connected to the PC. Printer Driver Down Loaded from HP Website for the printer. It...
If it is going through the motions of printing, the head is moving back and forward as it should, then this is a simple cartridge issue. Sometimes if the printer has been unused for a while the cartridges can semi-dry. try this link below to get them flowing again. http://www.fixya.com/support/r3986425-unblock_print_heads
Hope this helps GM
Apr 11, 2011 | HP D1560 Deskjet Printer InkJet
I freshly installed xp os but my system pentium4
your pc is not compatible with windows xp, try yo upgrade your pc first.
hope this will help sir! thanks!
Jun 29, 2010 | Office Equipment & Supplies
I have tvs msp 245 9 pin we get print only compressed mode how to change the mode
dear sir ji maine purana printer TVS MPS 245 LIYA HAI AUR MAIN WINDOW XP CHALA RAHA HUN PAR IS PRINTER KE DRIVER NAHI MIL RAHE HAIN PLZ SIR JI MERI HELP KAR DIJIYE
Feb 13, 2010 | Office Equipment & Supplies
Printer will not print because of another login's HP splash scree
dear sir
for this solutation u need to use password for yr printer shareng just chek yr password for printershare setting and give any password key it's help u...:)
thanks
plase vote
jo_chinmay
Jan 05, 2009 | HP Deskjet F335 All-In-One InkJet Printer
Cannot print over the network
dear sir..
for vista u ned to install "netbui" componant to network device and when u install it's u need to connect mac pc to vista thru network then it's connected it's worked... it's help u..:0
dear sir,
there is no need to install any drvier install in to windows xp if yr pronter allreadt install in pc then right click on printer then got to shring then select share as then give a name... after this prossess go to windows vista and open yr pc thru yr network placess it's show printer which connected to windows xp just dabble click then it's show u "Are u sure to install network printer" somthing like that... just click yes or ok... it's help you..:)
dear sir,
her eu have a chek yr kvm switch is connected thru earth.. this becouse some of time eart bypass thru switching yr monitor keyboard and mouses and mosr of time laptop don't face high static electricity.. it's first chance........ other is that yr pc has serious visus problem may be it's face thru Pen drvier or a internet or a some cd's which has infaction before data write in to cd.. so have to cek virus........ one more thing happen if yr pc is connated thru electticity and yr laptop is thru battry that time when u switch yr kvm module it's pass bunch of power so u have to chek all this thing's it's help u...:)
thanks
plese vote
jo_chinmay
Nov 23, 2008 | HP PSC 1350v All-In-One InkJet Printer
ML-1610 Laser Printer
hello sir first u install dos base drivers from your printer cd -see below
go control panel printers and faxes select dos base defalt print ok by if any problem uday_uday2004@rediffmail.com
May 19, 2008 | Samsung ML 1610 Laser Printer
PRINTING ON CUSTOM SIZE PAPER
you need to change the page lenght on the printer. to do so...
  1. turn off printer
  2. press and hold the tear off button while turning on the printer
  3. a menu of the setting will be printed
  4. just follow the instruction
  5. you need to set the page lenght for tractor feeding to 8inchs
turn off the printer it willsave the setting
Jan 01, 2008 | Epson LX-300+ II Matrix Printer
Epson TM-U220D Printer Status
Hi, On the PC that will not display printer status correctly, pls run MSCONFIG (start, run, type "msconfig", OK); in the System Configuration Utility Window, click on the tab Startup, see if the EPSON Status Monitor is present and checked. If it is not present, check if you have Lavasoft Ad-Watch or similar program running. This prevents the EPSON Status Monitor from registering and running correctly. If such a program is running, temporarily remove Automatic setting and reinstall the EPSON Status Monitor. Accept any registry modification at this point. Restore all settings once installation is finished. If still a no go, try wiggling the parallel connector a bit and make sure it is snug and fit. If all else fails, you may have to consider: Installing to only 1 PC, share and make it a print server assuming you have networked all your PCs; or re-installing Windows (Ouch!) Hope things work out for you. Pls post again how things turn up. Kind regards.
Jul 30, 2007 | Epson TM-U220D Matrix Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
HP DeskJet 1280 InkJet Printer Logo
114 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
