Question about Minn Kota Maxxum 70 Universal Motor/Sonar Combo
Minn Kota Maxxum Trolling Motor
Does not turn on. All wires connected. All batteries charged. No juice to the motor. Where do I start? Also, when trying to remove the prop the shaft turns with the nut. Am I in trouble?
  • Anonymous Apr 25, 2009
    When I plug in my trolling motor I here a click at the motor but I cant get It to do any thing else
    Problem Solver:
  • 11 Answers
I had the same problems with my 70lb, my motor just quit while on the lake, took it to a minn kota service repair shop. I had two issues. One was the little magnet under the button on the foot pedal got recessed to far down, the tech told me if it happened again pop the button off and pull the magnet up some. Simple fix. I took it home put it back on the boat and nothing just a slight ticking noise heard from the pedal with no prop movement. So I thought maybe somethin was wrong with one of my batteries. Unhooked everything, tested both of them, all good. Even though there was hardly any corrosion, I clean everything, hooked it up and "WALLA"! Power! Problem solved, for now. Waitng to test again out on the lake
Posted on May 01, 2009
Have 12 V bow mount trolling motor that doesn't start working until power is on for about 5 minutes. Then when it does start, have to have the power on 10 just to keep the prop moving. Checked prop and...
Hello, You have several points to check. #1 check your wiring connections--- plug, plug socket, wiring connections internal of trolling motor, condition of wiring to battery, battery terminal connection & charge of battery. #2 borrow someones DVM (digital multimeter) and check the resistance of the speed control as you turn it without any wires connected to it. #3 if problem not found take 2 aspirin and E-mail me of test results "for further review".
Sep 18, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Old outboard ground wire melting
1. Short in the trolling motor itself
2. TOO SMALL a ground wire. ..need at least 8 gauge wire!!!!
3. Bad/dirty/corroded battery connections
..Make sure your battery/trolling motor is not accidentally touching the metal boat.. DO NOT CONNECT ANY WIRES TO THE BOAT!!! - PERIOD!!.
Sep 11, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn-kota wiring battery charger 4 bank trolling motor e-drive
call the 800 number for minn kota on the head of your unit for questions or technical data. they will send you a copy of your manual also if you dont have it. i am not sure what your question is so ask them to save yourself time.
Jun 01, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Lookinf for a manual for a minn kota model 55d
call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Can you wire a minn kota foot control
.....I think so ;)
Here's a schematic, complete with wiring diagram:
Maxxum 70 Bowmount
Best of luck!
Mike
Jun 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Install
Click the link below, You do need to know your serial number thrust of motor and length of shaft as well how far away from trolling motor you will install your battery. This link is on Minn Kota Motors website under FAQ you can discuss with a service rep at Minn Kota please call 800-227-6433, but you will still need the information I asked earlier to come up with the answer.
http://www.minnkotamotors.com/_ui/sramk08/tpl/sramk_nohero_banner_faq-item.aspx?id=145&__taxonomyid=977
Apr 13, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Hook up for one battery operation for minn kota trolling motor
I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Apr 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
GPS Logo
478 people viewed this question
Top Minn Kota GPS Experts
Will Halftowaite
Are you a Minn Kota GPS Expert? Answer questions, earn points and help others
