Question about Insignia D400a PC Desktop
Video output how do i hook up my hi definition tv to my desktop?
  • 114 Answers
Does your HDTV have a VGA connector? If not you will have to use S-video to component video adaptor or HDMI adaptor.
Lou
Posted on Aug 24, 2008
I am trying to connect my ps3 to this TV. i have tried with AV ables and through HDMI but it does not seem to work. is there a problem with compatability?
hi,
PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that.
ok
Aug 29, 2011 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Tip
How To Connect Flat Panel TV to Computer
Hello <br /> First identify your TV's input connections. Most TVs these days have three basic types of inputs. You have your coaxial cable input, the same as your cable box or satellite, an RCA composite input (the yellow, red and white inputs) and an S-video connector. Newer televisions might have Component Video, DVI, VGA or HDMI inputs but the ones listed above are more common. <br /> Identify your computer's outputs. These days computer manufacturers are adding TV compatible outputs on their products so it's easy to have a pc to tv connection when you hook it up. The S-video in particular seems to be popping up on more and more computers, so a PC to TV S video connector might be what you need. You can shop for S-video cables all over the place online. Mostly you will find the usual VGA output that the regular monitor hooks up to (see more later on VGA cables). The newer multimedia computers will probably have all high definition outputs that connect directly to your HDTV, but for now we will deal with what most people have for both computers and televisions. <br /> Find the appropriate adapter for your connections. You may need to get a computer to TV cable so you can hook up your computer to the TV. If you have an HDTV, you may need a VGA to component cable. This VGA to component cable connects your computer to a HDTV and acts as a converter. (And that computer could be either a Mac or a PC.) <br /> A PC to tv connector has a VGA adapter on one end and (usually) a selection of connectors on the other (S-video, RCA composite and Component). The good thing about these is that you can take it from TV to TV and you'll be able to hook up computer to TV for all of them. I highly recommend a wireless adapter. It costs a bit more but wireless is worth not having a big cable mess and not keeping your computer near your TV. <br /> or you can get help from this video <br /><br /><img src="utube.png" /><b><i> You-Tube video "ZCN-nN1orYE" placeholder (do not delete) </i></b><img src="utube.png" /><br /><br />Hope this helps, if so do rate the Tip.<br />
on Jan 25, 2011 | Televison & Video
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
I am getting standard definition but not hd
Is your TV capable of displaying high definition? Is it an HDTV? If so, go to the Settings on your XMB (Press the Home Button) and into the Settings menu. Look for the option which says Display Settings. This will guide you through the configuration wizard and determine the best possible output for your TV. If it doesn't output at least 720p then your TV is not capable of displaying high definition.
Feb 22, 2011 | Sony Playstation 3 (PS3) Console
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
I have a tv screen which i use for my computer.I have the hdmi cords going from the video card on the back to my tv.why is it not working
Make sure your t.v. screen supports your display card resolution. Try lowering your display card resolution in display settings. Make sure your t.v. is set to AVI.
Best wishes,
Graemevm
Nov 13, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
Hook up a Sony VGC RA 840G desktop to a Samsung 46 inch TV
Some TV's don't have a VGA input. S-Video cable is more common. Look on the back of your computer an see if you have an S-Video jack. If you have a TV compatible output on your computer, such as an S-video jack, just take an S-video cable and connect it to your computer and your TV. If you do not, then attach your VGA end of your adapter to your computer and use the RCA, S-video or Component Video cable to attach to your TV. After you've made all the connections, make sure you are on the correct TV video input. Press the input button on your TV or remote until you see your computer's signal.
Apr 11, 2009 | Sony VAIO VGC-RA840G PC Desktop
Try to connect tv as a monitor
Does the desktop have an S-video output on its video card? If it does, you only have to get either an S-video cable and hook it up from the computer to the TV, or get an S-video cable plus an S-Video to composite adapter, and hook it up.
For the video card to output to S-Video, you may need to fiddle with something in the control panels, or unplug the regular monitor and reboot (at least on my NVidia 5600 cards, this forces the card into using the S-Video output).
Personally I think you will be very disappointed. Using normal computer applications while using your TV as a monitor will be basically impossible; the text will be too small and blurry. Web browsing on picture-and-headline type pages will be OK, but everything else? Instant headache. Most applications that are designed to be accessed via a TV screen instead of a TV monitor have huge font sizes and lots of contrast (cf. the TiVo's interface, for example); they're designed much differently than desktop apps. You may want to look into screen-magnification apps to make it easier on your eyes.
regards,
hope
Aug 18, 2008 | Compaq Computers & Internet
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
Aug 10, 2008 | Humax DRT800 TiVo Video Recorder
Insignia D400a PC Desktop Logo
Top Insignia Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Carlos L. Burgos
Carlos L. Burgos
Martin Clarke
Martin Clarke
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
