Smoke coming from back of washing machine and a burning rubber smell
  • Tina Wilson Aug 28, 2008
    ty so much the problem is fixed thx to you i did over load it so i took apart to check the belt and it seems fine now ty so.....tina
  • 706 Answers
You may have overloaded the washer and the belt drive system could not handle that excess mass.. The smoke and burning smell is a belt melting while trying to rotate the drum.. I would unload it .. gain access to the drive mechanism ( probably via an access panel in the back but may not be.. - brand and model specific).. and then check for damage to the drive belt.. You may look at the pulley system and look for burnt black from melted belt on it.. You could also have a clog in your pump that the belt drives but can't ( because of that clog) and therefore the belt rubs over the pump pulley and melts.. Could be any one of those things.. Hope that helps..
Posted on Aug 24, 2008
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Smell of burning rubber and smoke from drawer
Sounds like your drive belt is loose or worn out. You will probably need a new belt. Is it possible something got inside the machine and jammed the belt?
Dec 12, 2014 | Hoover Washing Machines
Westwood T1600 Smoking and burning smell?
Burning rubber smell indicates that you must have a worn out belt that is starting to slip making the burnt rubber smell. I think you need to replace at least one belt, maybe more upon inspection of the rest.
Jun 21, 2014 | Garden
Maytag Neptune frontloader washer smoking last few minutes of spin cycle
I need more information can you tell me if the smoke smells like rubber burning or if it smells like electricity burning like the wires burning?
Oct 01, 2012 | Washing Machines
Smoke burning rubber smell from my washing machine
have you removed all the lint in the back panel and oiled the berringsif not you may need new ones
Apr 05, 2012 | Whirlpool Washing Machines
The washine machine finished it's cycle but there was smoke coming out of the drum and a burning rubber smell
The usual cause of smoke coming out of drum is that the heater element has come on or stayed on with no water in the drum
Try it on a spin cycle only, if smoke still comes out of drum, then could be a faulty pump, or main motor is burning.
Jan 20, 2010 | Baumatic BTWM4 Front Load Washer
Smell like burning rubber
if it smell's like rubber it likley is .. smell's like a belt driven and it needs a replacment belt & idler .. remove the two screws at the bottom of front panel an remove .. in the front center at the bottom .is the motor / belt and pump .. if there is black rubber in bottom / wala . the belt is burning . / look for pump leakage / this would get belt wet and slip.. thanks mm .
Dec 02, 2009 | Amana 3.2 cu. ft. Top-Load Washer
LG washer, rubber burning smell
Did you get this seal problem resolved, by yourself or did you call in a repair-person? If you did it yourself, was it difficult? Same problem found 12/17/10 - Thank you
Mar 16, 2009 | LG WM1812C Front Load Washer
Smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Oct 06, 2008 | Frigidaire GLWS1339CS Top Load Washer
Washing Machines Logo
400 people viewed this question
Top Washing Machines Experts
