Question about Kenmore Elite 45986 Front Load Washer
He5t Kenmore ELITE front load washer flashing f35 code
I put a smal load in my washer on the delicate cycle, pressed and held start button, door locked, water started and I saw the fluids enter the drum, then got F35 error after.
  • 5 more comments
  • lacrss Oct 10, 2008
    Put the load in, everything seems fine, then the washer stops and I get the F35 code. I have to press the stop button, the washer drains, the clothes are soaking wet. Took everything out and reloaded them. I got the same F35 code. Tried a different load, which worked fine. Tried a third, different load and got the F35 code again. I just want to be able to wash my family's clothes. It's getting frustrating. Any assistance would be greatly appreciated.
  • amysmu Oct 14, 2008
    I have the same problem!! F35 error message is not in the manual. Don't know what the problem is. Sears can't seem to figure it out either now that I am on the phone with them!
  • 1angel2008 Dec 04, 2008
    I also put in a small load of clothes on a regular cycle and it washed normal for a while and then appeared the F35 error code. Contacted Sears the guy first told me that the code was not there then he said that it was the machines inablilty to determine how much water (water level) is inside the machine. However this requires a tech to fix. I have not had this washer for a year yet and it already needs service...disapointed...but a great machine when it works right. So I now have to figure out another way to wash my clothes for 5 days.
  • Robyn796 Dec 15, 2008
    I screwed up and bought non HE detergent.  Of course we didn't find out until after trying to figure out why our washer was flashing F 35, and it isn't in the manual.  My husband saw that the detergent was bad, and we immediately stopped using it and bought the correct detergent.  We ran several maintenance cycles, but it still only works sometimes.  Maybe after 3 or 4 attempts I finally get the washer to run a cycle.  Sometimes that doesn't even work.  We still have F35 flashing.  I just want to be able to wash clothes.  So frustrated.
  • greid67 Jan 08, 2009
    We are having the same problem with our Kenmore "Elite" Washer. F35 Code and door locks - cant even turn off the machine. Looks like Sears needs to get on top of this right away.
  • wehbeh1 Feb 04, 2009
    Was anyone able to figure out the problem? What DID the F35 code mean & how could it be fixed??
  • giampietr668 May 25, 2010
    what does the pressure switch look like
    President:
  • 744 Answers
Hi, Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch. If you have any further questions or concerns please feel free to comment again, Good luck.
Posted on Jul 07, 2009
  • 1 more comment
  • Mike Price
    Mike Price Jun 10, 2010
    Take the top off the washer by removing the 3 screws along the back. Then look to the back right for the part with the small plastic tube attached. That is the pressure/water level switch.
  • LitteTush Jul 23, 2011
    I Just fixed My Whirlpool Duet Steam washer that had a F35 error. I did just what? you said!!! This great! My wife is going to think I am a Genius! This video is awesome. Just washed a load!!!!
  • wildspiritmo Jul 26, 2012
    Where exactly is the pressure switch? Is it the first switch on the left where the water lines come into or is it one of the three "relays" or switches on the backside of the washer where the water lines runs into? As far as i can see, there is no blockage on the first switch.
My washer is just over a year old and I got the same error F35....wash load cycle stopped and doors locked. I had to schedule Sears service to come in....at $80 only to find out the pressure switch has to be replaced and the hose. All together it will cost us $500 for a washer that is 1 year old. I wish I never left my Whirlpool Duet at our old house. I can't believe we have to pay practically 33% of the cost for repair a year later. I would not recommend this washer to anyone based on that. My husband is contacting Sears to complain - if there is a known issue, then they should recall it and pay for the fix.
Posted on Feb 27, 2010
What does the pressure switch look like?
Posted on Jan 11, 2010
Just wanted to say that searching for a pressure switch is about impossible. You will find it under a water level switch.
Posted on Jan 02, 2010
This machine is a farce! I cannot believe I wasted over 2,000 on this machine. I wish I had my " Real washing machine back!" Sears can have this back......
Posted on Dec 01, 2009
I hate my machine. Just over a year old, F35 failure code. Wish I still had my reliable Maytag. And this failure is on a machine that replaced the FIRST one of these **** I bought. So I've had not one, but TWO units fail within 15 months of purchase! Anyone else have this miserable experience? What a total sham these machines are. Sears is less than supportive of their "flagship" product name.
Posted on Jun 10, 2010
Same here I hate this kenmore elite he sears should fix this problem for free or show how to fix it with a video or something . The problems are the SUD and F 35 code. Someone should call Dateline..
Posted on Feb 05, 2011
  • Penny_Sam Feb 05, 2011
    If you go go managemylife.Com Mark T the expert he will have an image of what the analog pressure is and where it is located.
We have a kenmore elite he5t front load washer, that i just finished replacing the bellow on. after reassembling the front panels, i tried to start the washer to run a cleaning cycle, but all that happens...
Thats usually a sign that the door is still open. Make sure that when you put the bellows on the ring that goes around it was put on properly as well that way the door is actually fully closing engaging the door swithch and letting the machine know its ok to run.
Nov 07, 2010 | Kenmore Elite HE5t Washer
Code F35 on Kenmore Elite HE5t front loader washer.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite he5t steam washer gets F35 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F35
f 35 is not in my info book . if you remove front panel 3 screws at bottom . inside there is a tec sheet with the fault codes. i would ck the clean out for the pump . it is right in front when panel is off . this may solve your prob .. .. mm
Nov 22, 2009 | Kenmore Elite HE5t Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
I'm getting an F26 code on a Kenmore Elite he5t front load washer
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
7,504 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
