DDW-081 CD\DVD Recorder can't read CD
It reads DVD without problems
but if I insert CD - system can't see that
tried 2 bios updates BX32 and B375 but it didn't helped
OS -Windows XP with SP2 but it isn't OS matter because System can't boot from bootable CD
Hardware is properly detected by bios
but when i insert bootable CD inside it doesn't detect it either
  • Anonymous Aug 25, 2008
    I have LG Combo R/W DVD drive, which will read DVD without problem but when i insert cd to to the drive and if we double click on that it can't show ant data.
  • 519 Answers
It is possible for your optical drive to read only DVDs and not CD. This is most likely a fault with your drive and may need a repair or replacement.
Posted on Dec 03, 2008
I have dell studio-15 and lately the CD/DVD drive continously ejects any CD/DVD without reading it. It cannot be read. I cannot write onto any CD/DVD either.
1. Try to boot to your computer using the Operating system disk see if the OS disk ejects try step 2
2. Try to go to the BIOS by tapping F2 upon boot see if the cd/dvd drive ejects
3. The reason for this if the problem is reoccuring outside of windows then the problem is mechanical and cd/dvd drive needs to be replaced
4. Else we need to do Operating System Reinstall or format the hard drive
Thank you for choosing
Jun 14, 2011 | Dell Studio 15 Laptop
Tip
I have problem with DDW-081 recorder it doesn't read CD at all  it read DVD OK...
shove it We encourage you to use Tips and Tricks as a starting point for sharing your technical knowledge and know-how with other FixYa users.
on Aug 24, 2008 | Pioneer DVR-107D DVD±RW Burner
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
My panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Jun 25, 2009 | Panasonic DMRES15 DVD Recorder
DVD Code Problem No FVU
You need to install or update the Firmware. Go to www.panasonic.ca and search your model. You will then need to download the firmware for your player and burn it/mount it as an ISO file on to cd. Just follow the instructions and you'll be up and running in no time.
It took me about 25min, but it is working fine now.
May 28, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
My player says it cannot read disc
run the cleaner Dusc maybe the lense is dirty.
plz rate this post as good as u can so we can help others
Feb 08, 2009 | Lite On LVW-5005 DVD Recorder
HL-DT-ST DVD+RW GWA 4164B DOENSN'T WORK
open explorer and go to 'My Computer'
right click the DVD/CD-ROM Drive
click on the tab labeled 'Recording' (usually on the far right)
click the option that is labeled 'Enable CD recodring on this drive'
...and POOF, magic happens...
Dec 31, 2008 | Computers & Internet
LG RH299H HDD/DVD does not read purchased DVD's
To unlock the region limitation of your machine:
(all the following is done on the remote)
Press <Home>
Go to the Easy Setup Menu
Go to <Setup>
"Hover" the cursor block over the Lock symbol (don't enter yet)
Enter 0000 on the remote
A Congratulations message comes up.
Press <Enter>
Nov 18, 2008 | LG RH299 DVD Recorder/VCR
Samsung SHW08A DVD±RW doesn't burn dvd+r
Its because you need a firmware update. The media you are currently using isn't recognized. I stumbled in here with the same problem. I haven't been able to find an update, so I will probably have to try a different brand of disc myself. The burner worked fine until I tried using a new pack of Verbatim discs.
May 21, 2008 | Samsung SH-W162C 16x16x8x6x5x4 DVD +/-...
Lite-On LVW-5005 (DDW-813s)
I have same problem like you, but I have changed the DDW-813s to a new Lite-On DH-20A4P, it work perfectly, good as new. but you have to make some changes to fix it to the place
Oct 01, 2007 | Lite On LVW-5005 DVD Recorder
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
