Question about Bosch Benvenuto B20 Espresso & Coffee Maker
It tells me to empty the empty trays
I started the cleaning process, and emptied the trays. When I put them back in, it tells me to empty them. I cleaned the insides where the tray sits and cleaned the contacts. What next?
    New Friend:
After I cleaned the tabs really well, I still had the same problem. So, I took the back off so I could get to the "switches" that close the feedback circuits for the "Trays Missing" and "Clean Trays" messages. Long story short, you DON'T need to take the back off. You can solve the problem if you remove the trays and carefully remove the right side metal tab. This will stop the false readings, at least it did for me. Save the tab if for some reason you need to it later.
To remove the right side tab, use something like an eye glass screwdriver or butter knife to pry it up and out of the two small holding tabs. Then rotate the metal tab up and away from the tray and it will fall right off. Pictures below. It tells me to empty the empty trays - 4f1cdcd2-d7df-40ef-8d16-43d437e4dec6.jpg c6bb0855-3864-43d0-b86e-120b4aaeIt tells me to empty the empty trays - efea4040-122e-4c2e-a12a-82fd49d53aed.jpg://i.fixya.net/uploads/images/efea4040-122e-4c2e-a12a-82fd49d53aed.jpgIt tells me to empty the empty trays - 1576a5c1-1b26-4e60-b6b8-316d7495c20a.jpgaed.jpg 1576a5c1-1b26-4e60-b6b8-316d7495c20a.jpg
Posted on Jul 01, 2014
  • 7 Answers
Also clean the receptacle inside the machine (where the tray tabs connect). Q-tips or steel wool on a stick work well.
Posted on Sep 11, 2009
  • 3 Answers
You need to clean behind/around the tabs where they reach into the tray. I have this same problem all the time, you need a brush or something and running water to really get behind the tabs. For some reason the cleaning process seems to get lots of gunk behind the tabs.
Posted on Jan 03, 2009
My franke flaire machine keeps displaying empty drip tray its empty and clean and will not let me do any thing else can you help
AT THE BACK OF THE DRIP TRAY YOU HAVE CONTACTERS LIKE SWICH SOW ITS BEST TO REMOVE THE TRIP TRAY AND TELL THE HAIR DRYER DO THE JOB TRY AGAIN
Mar 03, 2016 | Franke Coffee Makers & Espresso Machines
Empty Tray
@Derekns74 How do you remove the switch? My C3000 also reads "EMPTY TRAY" constantly, even if the tray is empty and clean. It does not display the "EMPTY GROUNDS" error only "EMPTY TRAY"
If I remove the tray it display "TRAY MISSING" but whenever I insert the tray again, it reads "EMPTY TRAY"
On one occasion when our power went out, it fixed the machine, so that it stopped reading "EMPTY TRAY," but after a day or two it stopped working and displayed the same EMPTY TRAY error message again.
Aug 04, 2013 | Jura Capresso C3000 Espresso & Coffee...
I just went thru the entire decalcifying process and got to the final step, emptied the drip tray and coffee grounds bin, put the tray back into place, but can't get the display off of "empty...
You should Clean and dry the metal contacts on the back of the drip tray, ensuring that the gap between the contacts is clean and dry (if present, contacts not on all JURA models) Make sure that the plastic in between the contacts is clean
Sep 13, 2011 | Microwave Ovens
Took the tray out to empty it, put it back in but now it says tray empty and won't work
Check the two contacts at the back of the tray. Be sure they are cleans as well as the plastic space between them. Then using compressed air clean where the contacts enter the machine in the rear. Usually there is moisture back there and the machine assumes the tray is full of water.
Jul 26, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
I was going through the decalcifying process and the message "empty tray" displayed (Jura Compresso Impressa S8). I removed the tray, cleaned it, replaced it, but the message remains as "empty tray" and I...
I had the same problem and had success with cleaning the contacts in the back of the machine with a small nail file/emery board. I found that the contacts that are inside the machine had a little calisification on them. Once they were cleaned up no problem.
Aug 15, 2010 | Jura Capresso Impressa S8 Coffee Maker,...
Stuck in cleaning mode?
Open the preground coffee lid, drop a cleaning tablet in it, let it do it's tablet cleaning cycle. After cycle empty water out of tray and clean.
May 16, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
Impressa E8: even though I did clean machine, it asks me again...
Make sure your water tank to fill, when you start the clean process, and the tray is empty and wiped down. Then add a 500ml container under the spout rather than let the water go into the tray.
Also if you have not serviced the machine for about 5,000 cups this can occur.
Mar 23, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Jul 11, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Problem with Benvenuto B30 cleaning
To remove the right side tab, use something like an eye glass screwdriver or butter knife to pry it up and out of the two small holding tabs. Then rotate the metal tab up and away from the tray and it will fall right off. Pictures below. a9c5bc58-d1a4-488c-891c-2b50084d4d96.jpg 3a317125-915d-4f72-a472-8ae2ea938a3a.jpg 383c8eeb-4d14-467d-842b-ea47d989e30b.jpg bd453672-83d3-46db-8ab5-d9cac5576ad8.jpg da367966-03c1-462d-961c-c5a9605fe4f4.jpg
Dec 09, 2007 | Bosch Benvenuto B30 Espresso/Coffee Maker
Bosch Benvenuto B20 Espresso & Coffee Maker Logo
893 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
Oloyede Monsuru
ray gallant
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
