Question about Samsung ML2250 Laser Printer
ML2250 Laser Upon turn on it groans and squeaks. This goes on for 10-15 seconds, then the noise stops and the red error light comes on. Could this be a bad cartridge? There is no paper caught in the machine. It has printed less than 1000 copies. Thanks
Dead/dry fan bearing.  Either: * order a new fan and replace it  * peel off the sticker on the fan and add a tiny drop of sewing machine oil - I did and has fixed mine (not sure how long)
Pretty easy machine to disassamble without a manual as long as you don't force anything. Well engineered 2- 4 screws for each panel and some very mild flexing of panel clips required. Remove in order: back cover (ease past power switch); top cover - have to lift to about 30deg at front; front cover (unplug wire to light assembly, unclip top + push forward); side cover (note hooks on bottom; unclip top and push to rear).
Posted on Nov 13, 2008
Squeaking suspention
The Explorer has an unusual front suspension called a Torsion Bar system (no springs). As they get older, they squeak and groan.
All the parts are put together with bushings between the metal parts, and as these get older, the get dry and inflexible. And this causes the groans and squeaks.
At worst, they can make your handling sloppy. A new set of control arms, tie rod ends and ball joints is about $200 in parts, plus 3 hours of shop time to replace them. When you replace these parts you also get new bushings which usually stops the noises.
Oct 26, 2013 | 1996 Ford Explorer
Online error
problem with Samsung ML2250 laser printer when power on the printer it is blinking green light after few second red light is blinking what is the problem. i am changing the fuser & toner also when i got same problem please help me to give better solution.
Jul 11, 2011 | Samsung ML2250 Laser Printer
My Samsung ML-2250 printer sounds like it's starting to print a page but then it just stops and the red light comes on.
Hi ,
kindly Open His Cartage Cover , And try to have a look in Imagining Unit , I think Its not fixed Properly.
Shahzad Rashid IT Hardware/Software Engineer
Feb 17, 2011 | Samsung ML2250 Laser Printer
Groaning Noise While AC is on
this sounds like the AC compressor is failing, the engine idles slower in drive so noise is more apparent. you are likely going to need to replace it soon.
Jul 23, 2009 | 2007 Suzuki Forenza Sedan
Samsung ML-2250 red light
Check the paper tray. There's a latch along the lower left edge that's supposed to let the paper pop up when the tray is inserted so it can feed. If the tray looks OK, check the paper path again and look for a torn off piece of something in there. All it takes is one little piece of paper jammed in there to make the light come on. Use a flashlight and try blowing some air through it with the tray out, back door open and cartridge removed.
Mar 09, 2009 | Samsung ML2250 Laser Printer
On Line / Error Red light comes on.
recheck connections and shut windows down completely for 5 minutes before rebooting.... then if it still doesnt see it.. go to samsung site and download latest drivers and uninstall/reinstall with new...good luck
Dec 08, 2008 | Samsung ML2250 Laser Printer
Samsung ML2250 Laser Printer Logo
450 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
