I have a Hotpoint WF440 washing machine which makes a loud noise when washing, and an even louder noise when spinning. Sounds like bearing trouble. Any ideas, please?
  • Aud B Aug 25, 2008
    Thanks WASHDOCTOR, your solution to my problem appears to be the correct one.
    I intend to attempt the repair myself and would appreciate any advice in achieving such.
    I look forward to to hearing from you again soon.
    Best Regards
    Aud B
  • 139 Answers
This definatley bearing trouble. its one where you can fix yourself ONLY if your willing to take up the whole day doing it..
The problem with bearings is that once you get to them, it can be tricky taking them out of the shaft because they can crack and leave the outer shell of the bearing in the machine.
if you wanna try it your self then i have a similar solution you can use posted for a wma. the only thing diffrence is that its easier than the wma..
cheer washdoctor
just let me know if you need help
Posted on Aug 24, 2008
Whirlpool cabrio started making a loud noise when spinning. I've replaced the suspension springs before. Is that all I need to order? It's been a while.
Sounds like the bearings are toast. These machines have a poor seal in the tub which allows water to penetrate the bearings, drying/rusting them out. Go on "youtube" and search your problem. I use a 2"X4" and a jack on the center shaft to lift the drum out. Bearing tool and shaft/bearing, seal kit is approx. $150. Should take you approx. 4 hrs. if you're handy.
Nov 28, 2016 | Whirlpool Washing Machines
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
Loud noise when spinning and pieces of frayed plastic found inside washer
sounds like the motor bearing has gone and the pastic your finding is the bearing housing the loud noise is the drum banging on the side of the machine, you will need new bearing or bushes it will still work just be noisey and will get even louder eventually.
May 04, 2014 | Whirlpool Washing Machines
Hello, my washing machine is making a very loud noise, even louder when spinning?
the drum bearings are bad,it costs anywhere from $400.00 to $900.00 to replace them and possibly more if you need to replace the inner tub with the bearings
Aug 20, 2011 | LG WM2277H Front Load Washer
Washing machine makes a loud vibrating noise when spinning and sprays grease onto washing
It sounds like the main bearings have failed, try turning the drum by hand, if it feels rough or is niosy, then the bearings have failed.
Oct 25, 2010 | Hotpoint Washing Machines
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Maytag washing mchine makes a loud noise when on spin.
It sounds like your main bearing has gone out. It's quite an expense to fix and generally isn't worth fixing even if you do the repair yourself as the parts run about $600 by themselves and it takes about 1/2 a day to replace them. You can't replace the bearing itself so you have to replace the rear half of the outter tub and the inner tub.
Mar 29, 2010 | Maytag Washing Machines
When spinning it seems the washer is getting louder and louder during the spin cycle. It is a very steady noise no grinding to it. Maybe a bearing?
make sure heavy items are evenly distributed in the barrel. if to loud , stop the machin by openning the lid and make sure the weight is evenly distributed. never just throw laundry in , place it so wieght is evenly placed around.
Jun 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
204 people viewed this question
Top Washing Machines Experts
