Question about Krups GVX2-12 Electric Burr Grinder
Fill out water
Where do I fill out water in this coffee machine. Thanks
The Krups Burr Grinder GVX2 featured in the picture is not a coffee maker, per se, it only grind coffee beans to use in other coffee makers. It is a lousy machine, and I would recommend returning it or not buying it.
DO NOT PUT WATER INTO THIS MACHINE. It will cause electric shock.
Posted on Jan 09, 2009
Metallic tasting coffee
You need to look in your manual and descale the unit. When you do this, make sure you use vinegar and water. This will take care of most of that. Also when filling your machine with water, if you use bottled water or going through a good water filter system will help this. So, between descaling the machine, with vinegar and water, and filtered water will help this go away. Thanks Mike
Please rate my solution if this was helpful. Thanks.
Sep 30, 2011 | Keurig B70 Coffee Maker
It's blinking de-scale side water holder gets r4eally hot water is not coming out properlywhen u press one of the cup size bottons
This is the time, you need to Descale the machine. The simple procedure is :-
Unfortunately, in spite of the best-laid plans of mice and men, espresso machines often get clogged by scale, deposits of minerals from hard water. Scale can cause serious damage if untreated. If your espresso machine's water flow has decreased a lot, it's probably because of scale. Fortunately, there is an easy and inexpensive way to descale your espresso machine.
  1. Obtain some citric acid. You can either order this online or find it in the kosher foods section of the supermarket (usually marketed as "sour salt"). Acid solutions dissolve scale, which is made of calcium carbonate. There are special solutions marketed specifically for descaling, but citric acid works just as well and is much cheaper.
  2. Prepare the descaling solution by mixing citric acid with water (I use two tablespoons of acid and a quart of water).
  3. Put the descaling solution in the water tank, turn on the machine, and run water through the steam wand until the cup is filled, to expose the parts to the solution. Turn off the machine, and leave it for 20 minutes so that the solution has time to dissolve scale.
  4. After 20 minutes, run more water
  5. Run solution through the machine every 20 minutes, until the water tank is empty.
  6. Fill the water tank with plain water, and run water through the machine until output water no longer tastes sour. This is important, because excess citric acid does not make coffee taste good.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 12, 2009 | Keurig Coffee Makers & Espresso Machines
XP7230 does not work with Claris F088 filter cartridge installed
You have the filter screwed it too far. As soon as you feel the filter seating do not screw it in any further.
Apr 30, 2009 | Krups XP7230 Compact Super Automatic...
Error Message
Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting! Also, use a spell-checker before improving this posting.
To clean hard water deposits from a coffee maker use distilled white vinager. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinager and run through machine as if making coffee. Repeat this process several times using fresh vinager until it comes out clear. Do this once a week and your maker will work much better.
Thanks.
Mar 24, 2009 | Coffee Makers & Espresso Machines
B100 putting out very little water, reservoir is full
bye descaling product for the coffee maker not vinegar put descaler in machine fill with water start leave it running for 10 seconds close it for 15 minute start it up again repeat untill empty after its empty fill it with water run it untill empty repeat again descaler is acid so you need to rinse very good try it out thanks pierre
Jan 11, 2009 | Keurig B100 Coffee Maker
Seaco coffee machine
I think you is in "rinsing cycle" on the machine, you have to fill up the water tank with water and after that open the steam knob.
Jun 23, 2008 | Saeco Incanto Classic Espresso Machine
Water fill light stuck on
you say our fill the water light stay on lot they put a magnet in the water container fill it with water and gently tap the water container if the magnet stuck that should do it if it persite the magnet receiver under the cover is diffective normaly a few little tap do the trick
thanks for using fixya
pierre
Feb 25, 2008 | Saeco Incanto Classic Espresso Machine
Expresso machine
descaling gonna improved the pressure = stronger coffee and clean the inner boiler =warmer coffee but use descaler only not vinegar descaler melt calcium vinegar remove some calcium in littlt piece 1 part descaler 1 part water fill the water container open valve for a few second close it leave it for 15 minute and repeat untill empty after rince very good that stuff is corosif
THANKS FOR USING FIXYA
FROM MONTREAL CANADA PIERRE
Feb 18, 2008 | DeLonghi BAR 14 Espresso Machine
Amount of coffee produced
you clean the filter with what vinegar you need to use descaler descaler melt calcium vinegar vinegar remove calcium in pieces that might block the machine use descaler 1 part descaler 1 part water put solution in the water tank start the machine after a few second turn it of wait 10 to 15 minute after repeat untill empty rinse very good 2 or 3 full rinse that stuff is corosif thanks for using fixya pierre
Feb 09, 2008 | Philips Senseo HD-7810 Coffee Maker
Krups GVX2-12 Electric Burr Grinder Logo
278 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
