Question about Kodak EASYSHARE G610 Thermal Printer
My printer makes noise like its sucking in the paper.
But then it doesnt and my screen says add paper?
Feed wheels are likey dirty with clean hand rub your thumb across the feed wheel with a little pressure make sure you do all three feed wheels
Posted on Nov 08, 2008
My hp laserjet m1522nf makes a grinding noise and then says add paper' it also makes the same noise when i shut it down and power it up again ... does this mean the printer is garbage?
it could be a bad toner cartridge
try replacing each toner cartridge one by one to see if grinding gear noise goes away.
Or
it could be jammed paper somewhere inside the printer
Feb 03, 2017 | HP Laserjet M1522nf All-in-one Laser...
My Printer says I'm 'out of paper' but I'm not, any ideas? Thanks.
If it doesn't make any feed noises trying to retrieve the paper restart the printer.
If It is attempted to feed paper remove all your paper in the tray and then add again.
Sep 09, 2010 | HP Office Equipment & Supplies
Add paper symbol is lit, paper is in it, but it w...
Paper tray up motor unit is available , in that unit there will be a tray up gear , it may warn out, you have to replace the gear
May 20, 2010 | Toshiba 2060 Copier
The printer says "paper Jam" but no paper is in it. When ever i click "ok" it makes a loud noise and says "please wait" but it doesnt do anything. What do i do?
Dont worry about that. Try to visit this website this website it will help you to solve that paper Jam kodak.com/go/stepbystep
Nov 19, 2009 | Kodak ESP 5 Printer
Printer is grinding
sounds Like a paper jam , Plus your paper feed rollers are dirty, clear any paper inside the printer, the using a cloth rag and some 409 cleaner , wipe feed rollers to remove white paper dust on rollers, and let dry, then add paper to printer and it should print.
Jul 21, 2009 | Office Equipment & Supplies
Noise
The only real common noise on that machine that I can think of is in the tray 3/4 module. When it goes to feed paper there is a gear chain that looses mesh and makes noise, doesnt feed paper , just shuts off.
Other than that, I have not seen many noises from that product.
Mar 28, 2009 | Xerox WorkCentre Pro C133 Printer
Paper will not feed.
Hi, my name is Alex and I am here to help solve your problem regarding your printer.
Please make sure the paper is preloaded into the printer before selecting print. Also please try turning the printer off and then turn it back on and make sure the paper is loaded when doing this. This is normally a common problem so nothing to be worried about.
One other thing to do, please check inside the printer and make sure no paper is trapped in there, there shouldnt be as you would get the paper jammed window on your screen but when little bits of paper get left inside the printer, when the new paper goes to get fed inside the printer, it doesnt go down properly.
I hope this makes sense to you. Please let me know if you experience any more problems.
Nov 04, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer R300
make sure you have the paper where it hits the part that sucks in the page to be printed (you can see the gray stucture by removing the paper and looking into where the paper is put) this might cause your papers, if you have a small amount, to bend to where the dip of the curve is facing the front of the printer. *Also the best way to prevent this is by having a LOT of paper where its fed (if the bending thing doesn't work.* Also the clicking noise is the sucking part not getting a piece of paper. This is because the paper not inserted correctly means that the pronter detects that paper is in the pronter but it can't get it.
Oct 15, 2008 | Epson Stylus Photo R300 InkJet Printer
Kodak EASYSHARE G610 Thermal Printer Logo
105 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
